Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-15-2017, 06:51   #46 (permalink)
Member: 2575005
Thanks Meter: 41
Originally Posted by jmr View Post
can add whatsapp group?
Send PM to @magdani
Enviado desde mi MI 5 mediante Tapatalk
The Following User Says Thank You to TecnoLatinosGSM For This Useful Post:
Old 08-21-2017, 10:09   #47 (permalink)
Crazy Poster
Member: 61446
I have ipad air 2 with this (waiting for ipad ) give me the solution ?
Old 08-21-2017, 16:45   #48 (permalink)
dam1inc's Avatar
Member: 1866487
Thanks Meter: 113
It's not that easy as "give you solution"....do you get "waiting for ipad" with nand attached?
Sent from my SM-G955U using Tapatalk
Old 08-22-2017, 08:46   #49 (permalink)
Member: 2582013
Thanks Meter: 2
Hello guys i have also 3x ipad air 2 lte and i have already this WIFI ic from aliexpress .... because of the IC is very thick ... what is the temp/time that u work on that because its not as easy as the other ICs .... i have a friend that works around 350c for 3 4 minutes and then its again hard to remove it because of the F**** black resin under ... give me tips of the TEMP/TIME before i start guys , thank you in advance , i like this thread , i am following
Old 08-23-2017, 06:53   #50 (permalink)
Member: 2691507
Thanks Meter: 100
The temperature if fine for that IC but you need to work fast.
4 minutes is to long.
shield everything around the IC
Pre-heat the board for about 30 seconds 180% is fine, then increase heat to 350c (melting point of lead free solder)
You need a very fine spatula or you can use a pin like the ones that come in clothing (very fine)
Push the spatula or pin under one side only, but keep heat even and do that one by one until you raise the IC, you'll need at least 2-3 pins
If using spatula work just 1 mm on the edge free of components (no pads there) once in move it side to side (1 mm in) that helps separate on that side, then on one edge push spatula all the way in, take it out, go to the other side and do the same, at this point your IC might just pop up and if not then slide the spatula inserted all the way in from side to side (SLOW)
Something you need to pay attention is to push Horizontal (NOT IN AN ANGLE)
All that needs to be done under 2 minutes.
Remember is not the solder holding the IC is the Glue so you don't need to keep putting more heat on the board or you'll damage other components.
Old 10-21-2018, 19:42   #51 (permalink)
Member: 2691507
Thanks Meter: 100
WOW memories ....
Came across my old post when working on the iPad Air 2, I finally figured how to fix the elusive "waiting for ipad" itunes error
pad-air-2-error-4014-after-change-nand-serial
Old 10-21-2018, 20:08   #52 (permalink)
Member: 2575005
Thanks Meter: 41
How you fix that bro
Originally Posted by cisco2017 View Post
WOW memories ....
Enviado desde mi Redmi 4X mediante Tapatalk
Old 10-22-2018, 07:51   #53 (permalink)
Member: 2461303
Thanks Meter: 65
I'm currently working on iPad Pro no wifi after wifi IC change, then I'll go back to the Air 2.
I'll keep you posted.
error 4014 in ipad air 2 coming by SDRAM , before sombody overheat flash ic for 4013 -i first change flashic then the 4014 error comes,next i reball SDRAM it works .flashing fully done
The Following User Says Thank You to EAKANATH For This Useful Post:
Old 10-22-2018, 11:05   #54 (permalink)
Member: 2691507
Thanks Meter: 100
Interesting, you must to have heat up that main board a lot.
Old 10-22-2018, 12:40   #55 (permalink)
Member: 2461303
Thanks Meter: 65
its difficult to clean gum down side of SDRAM
Old 11-08-2018, 20:20   #56 (permalink)
Member: 1675922
Thanks Meter: 61
have two air2 boards that after removing nand are detected in dfu -> disconnect -> dfu again and that's it...
my guess was that the ram is causing the issue, but on another board with same symtoms after remove ram the balls seemed ok, without bridges...
any idea?
thx!
Old 11-11-2018, 07:38   #57 (permalink)
Member: 2691507
Thanks Meter: 100
any idea?
thx!
You need to be more specific on what you did and the error that you are getting.
Try a restore with 3utools and pay attention to the error on the animated graphic, why, read my link on how I fixed "waiting for ipad"
Description on what you did helps to diagnose basic problems like over heating surrounding IC
is short: Need
Work history steps
Temperature
shield used or not
Line test (voltage)
Did you check Nand pads on the board & Nand (some times they become lose if you use to much heat)
Error codes
Post as much information so that our viewers can help you and others can learn.
How I fixed waiting for ipad
Old 11-11-2018, 18:22   #58 (permalink)
Member: 1675922
Thanks Meter: 61
any idea?
thx!
I used 350 degrees for nand removal.
Without nand, on itunes i get error 4014 and on 3utools not able to go from dfu to recovery
Didn't tried to re-attach a nand...
i desoldered and solder back all nearby ICs (except ram ofc): U3000, U2000, U2180, U7503
On 3utools it stuck on 11% enter recovery mode: unable to go from dfu to recovery
PSU shows 50mA when disconnected from USB, and 0 when connected
All voltatges seem normal and steady.
Thx!
Old 11-11-2018, 19:15   #59 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
Thx!
ERROR 4014 some time Nand is not properly attached to logic board remove nand reball it and resolder it back again ..................
Old 11-11-2018, 22:53   #60 (permalink)
Member: 1675922
Thanks Meter: 61
thx for the answer.
i know about error 4014 due to improper nand programming.
but also the board should be able to enter in recovery without nand - this is my case..
thx again!
Page generated in 0.61587 seconds with 8 queries
