07-08-2020, 10:24 | #1 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2114773 Status: Offline Thanks Meter: 20 | iPad Air 2 USB device not recognised after NAND change First befor i remove Nand ipad works just it had icloud,after removal and change serial number and solder it back ipad usb not reconised by pc,i remove nand and conect to pc without it,same problem,i see on forum that pc must reconise it without nand to.Cpu and Ram was protected with temp. tape, 20cent coin and shield -try 5 diferent usb cable -2 diferent pc -no heat on board -cpu cold -no short on caps -no missing caps I dont know what to do and i remove u2 on end just to try something and one pin is missing ,dont know is that pin cause the problem and where it go,dont have for this model a pcb layout. here is a photo from U2 missing pin and here how i protect CPU and RAM https://ibb.co/HYQ2RJt Last edited by edin2008; 07-08-2020 at 10:31. |
07-08-2020, 14:03 | #4 (permalink) |
Member: 2114773 Status: Offline Thanks Meter: 20 | |
07-08-2020, 14:47 | #5 (permalink) | |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote: no need to conect leave it missing check another option replace good cable new ic | |
07-08-2020, 14:54 | #6 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | yes ipad must be detected in dfu mode without nand ic.. here is software you can use for https://phoneboard.co/ |
The Following User Says Thank You to chand_gee For This Useful Post: |
07-08-2020, 15:31 | #7 (permalink) | |
Member: 2114773 Status: Offline Thanks Meter: 20 | Quote:
thank you for the software i need it a long time. the U2 i eplace now same problem cant reconise pc | |
