01-19-2017, 22:31 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2220206 Status: Offline Sonork: 100.1625182 Thanks Meter: 0 | IPad air A1475 Not charging |
01-20-2017, 23:58 | #4 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Earth
Member: 813803 Status: Offline Thanks Meter: 120 | http://forum.gsmhosting.com/vbb/f631...-here-2180895/ Download schematics then open iPad Air schematic and search for C8145. Not hard!! Sent from my iPhone using Tapatalk Pro |
The Following User Says Thank You to zarbourne For This Useful Post: |
01-21-2017, 01:10 | #6 (permalink) |
Member: 813803 Status: Offline Thanks Meter: 120 | The password for that file is in the filename vietmobile.vn or something like that Sent from my iPhone using Tapatalk Pro |
01-27-2017, 17:03 | #7 (permalink) |
Member: 2220206 Status: Offline Sonork: 100.1625182 Thanks Meter: 0 | hey zarbourne, this is what i did, i changed the charging port and now i am getting power when the ipad is off but when it comes on it doesn't charge. i have also attached an image of my ipad air with voltages. Last edited by aligreat1; 01-27-2017 at 17:09. |
03-14-2017, 12:45 | #10 (permalink) |
Freak Poster Join Date: Sep 2005 Location: U.A.E Age: 43
Member: 182134 Status: Offline Thanks Meter: 16 | Same problem i received iPad Air A1474 when off show charging ok when power on no charging at all. i change charge flex cable and U6000 ( 1610A1/1610A2 ) both not work. any idea? |
03-14-2017, 18:45 | #11 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2653132 Status: Offline Thanks Meter: 2 | Same issue with 2 ipad minis (2nd & 3rd gen). Replaced u1300 w/ no change, then replaced q8104 w/ no change. Saw this thread. Check volt on c8145 and it shows ~4v. just replaced the q8123 w/ no change. ipads are not drawing power. Any ideas? |
03-25-2017, 03:00 | #12 (permalink) | |
Crazy Poster Join Date: Mar 2017
Member: 2697189 Status: Offline Thanks Meter: 37 | Quote:
I assume you changed the diodes as well? although D8100 would probably give HDFU so easy to spot. Now I realise this is gonna sound stupid but you did try a different battery at the start .... mostly I have noticed case cracking at 20x mag on failed tristar chips. I have lots of weird battery issues, 2 only fired up when heated else device not charging at all and device showing dead battery icon! lots that refuse to charge from logic board and suck the life out of my psu. I always use a known good battery now before i get the soldering iron turned on lol | |
03-28-2017, 21:49 | #13 (permalink) |
Member: 2653132 Status: Offline Thanks Meter: 2 | Have to give up on the 2 minis. Now have Air 1 with same issue. Verified C8145 has 5 volts. This runs into Q8123 (usb charging ic) which is receiving 5 volts but going out to DZ8120 is 0 volts. My guess it's either Q8123 or U8100 that is bad. Planning to replace u8123 and see what happens. |
