09-28-2019, 15:39 | #1 (permalink) |
Major Poster Join Date: Jan 2019 Location: Kansas City
Member: 2891996 Status: Offline Thanks Meter: 6 | iPad (charging to 1%) various models It will charge the battery when in "dead battery mode" and it is not booted up. But once it boots up it quits charging the battery. Current drops to zero and the battery charging stops. The display shows battery at 1% not charging. I have seen this several times and have not figured it out. I have crawled over the schematics Air 2 and Mini 2 but don't understand the process for turning on the charging. I see the signal out of the PMIC to turn it on. But don't know why it is missing. If anyone has figured this out please msg me or post on this thread. |
10-03-2019, 08:29 | #3 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | If already saw a lot of the from ipad air 1/2 mini 4 with charging up to 1% and then stops. This isnt tristar or dock flex. Sometimes the stay working if 2 amp ipad charger is used. Most of the time the PMIC is dead and needs to be replaced. I just trow them in the parts box since here the value of these ipads is too low now. |
10-03-2019, 21:19 | #4 (permalink) |
Member: 2891996 Status: Offline Thanks Meter: 6 | I figured it out. It works for multiple models. It's not the PMIC! Now the hard part of finding components for the iPad 6th Gen! This is a PITA signature fail across multiple models. I figured it out by reverse engineering the 6th gen using iPad air schematics. |
07-16-2020, 07:58 | #5 (permalink) |
Junior Member Join Date: Jul 2013 Location: Sweden
Member: 1990685 Status: Offline Thanks Meter: 2 | I've seen plenty of these. Keeps charging really good with a drained battery, but as soon as it boots up it stops and stays on 1%. Never tristar, dock or battery. What do you mean with PITA signature fail? Do you know how to fix that? Tried searching both schematics and the web for PITA but just find a lot about bread Does replacing PMIC help? |
08-12-2020, 13:30 | #7 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Denmark Age: 41
Member: 268415 Status: Offline Thanks Meter: 57 | I've fixed many of those with same problem. its always pmic. reball or replace, it will fix your problem. temporary solution is to turn it of manually while its on and connected to charger it'll charge battery in off state. |
The Following User Says Thank You to fasttechjlm For This Useful Post: |
