ipad mini 2 remove R1205 after only dfu mode im trying remove icloud ipad mini 2 1st remove r1205 and short this point ipad goes to dfu mode but not restore now ipad is dfu mode remove this short point but same dfu mode how to alive phone ?? i have not R1205 res Anyone Have Solution ???/ |
short r1205 and restore sw, it should work and go to previous state. if i'm not wrong for mini2 you need to remove r1204 to bypass icloud. by the way, in latest ios (11.x.x) you can't use wifi and bluetooth after bypass icloud in this way. |
short r1205 and remove r1204 done but not restore this ipad A1490 firmware |
What error code dose it shows? Is that battery have enough charge? take back you ipad to old hw configuration, like put all the parts as it is was before (if parts not available you can short) and remove where wasn't. manually download ipsw and restore it by pressing shift button. first try with 4g ipsw only. If your ipad power on normally then you can try to start bypass process from beginning. post the result. |
