Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-20-2018, 17:51   #1 (permalink)
Member: 2438408
Thanks Meter: 380
ipad mini 2 remove R1205 after only dfu mode
im trying remove icloud ipad mini 2
1st remove r1205 and short this point
ipad goes to dfu mode but not restore
now ipad is dfu mode
remove this short point but same dfu mode
how to alive phone ?? i have not R1205 res
Anyone Have Solution ???/
Old 07-21-2018, 08:18   #2 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 5,014
short r1205 and restore sw, it should work and go to previous state.
if i'm not wrong for mini2 you need to remove r1204 to bypass icloud.
by the way, in latest ios (11.x.x) you can't use wifi and bluetooth after bypass icloud in this way.
The Following 3 Users Say Thank You to tkowsar For This Useful Post:
Old 07-26-2018, 19:05   #3 (permalink)
Member: 2438408
Thanks Meter: 380
sir this ipad model A1490
short r1205 and remove r1204 done
but not restore this ipad A1490 firmware
Old 07-26-2018, 19:21   #4 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 5,014
What error code dose it shows?
Is that battery have enough charge?
take back you ipad to old hw configuration, like put all the parts as it is was before (if parts not available you can short) and remove where wasn't.
manually download ipsw and restore it by pressing shift button. first try with 4g ipsw only. If your ipad power on normally then you can try to start bypass process from beginning.
post the result.
Page generated in 0.14365 seconds with 9 queries
