Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-11-2016, 21:32   #1 (permalink)
Member: 1668980
Thanks Meter: 35
ipad Nand Ic compatible
Hi
can someone confirm if nand swap is compatible
with iphone 5 we can use in ipad mini 1 gen
I have been able to format and change serial on iphone 5 nand
then restore in ipad mini, but having problem with itunes restore
(waiting for ipad ). I have many cases of this happening
same with iphone 5S to ipad air or do i need to order same model nand ic?
has anyone tried this yet?
Thank you
Old 11-22-2016, 11:49   #2 (permalink)
Member: 2393089
Thanks Meter: 29
iPad 2 iPhone 4 revision with small NAND chip
iPad 3 (if 2 NAND flash chips than SN in U1400 chip?) iPhone 4s, iPhone 4 (?)
iPad 4 iPhone 5
iPad mini 1 gen iPhone5, iPhone 4? (revision with small NAND chip?)
iPad Air 1 gen iPhone 5s or iPhone 6
iPad mini 2 gen iPhone 5s
iPad Air 2 gen iPhone 6
iPad mini 3 gen
iPad Pro 1 gen iPhone 6s
iPad mini 4 gen
iPad Pro 8.9″ (Air 3) iPhone 6 or iPhone 6s
The Following 12 Users Say Thank You to Gsmsverige For This Useful Post:
Old 04-13-2017, 05:26   #3 (permalink)
Member: 1881219
nice info thanks for sharing
Old 04-13-2017, 08:36   #4 (permalink)
Member: 1939450
Thanks Meter: 165
iPad 4 iPhone 5
iPad mini 3 gen
iPad mini 4 gen
Some of the information above isn't 100% correct.
ipad Pro has a PCIE NAND not a 64 Bit nand so this is not correct. Then only iphone 6s should be compatible.
But people keep in mind that you can get problems with you gyroscope because of different driver installations in the NAND. Just use a flasher (ipbox, wl tool etc) to remove icloud properly.
The Following User Says Thank You to timvandenboo For This Useful Post:
Old 07-27-2017, 23:48   #5 (permalink)
dam1inc's Avatar
Member: 1866487
Thanks Meter: 113
does anyone know ipad mini 3 nand compatibility ? thanks
Old 07-28-2017, 00:17   #6 (permalink)
Member: 1190472
Thanks Meter: 9
Ipad air 2 works also with iphone 5s nand. Only screen orientation in landscape mode is upside down.
The Following 3 Users Say Thank You to rb0wag For This Useful Post:
Old 09-01-2017, 17:15   #7 (permalink)
Member: 1546723
it's any solution for the problem for the gyroscope ?? im using naviplus pro 3000 and JC N2, and i don`t find the solution for gyroscope yet
Old 09-17-2017, 10:16   #8 (permalink)
Member: 1520712
Thanks Meter: 19
where can we find a good serial nomber for ipad etc for naviplus?
is any site with clear serial or sometrhing becouse in luck type serial maybe must solder and desolder all the time any help i preciate
thanks in advance
Old 10-04-2017, 20:49   #9 (permalink)
Member: 2594096
Thanks Meter: 17
I got iPad 5th Gen 2017 so I actually need to remove icloud from it so will I swap it nand with iPhone 6S or I need to reprogram it first.
Old 11-29-2017, 00:34   #10 (permalink)
Member: 469257
Thanks Meter: 34
is iPhone's 5 NAND compatible with iPod 5th gen?
Old 02-04-2018, 03:16   #11 (permalink)
Member: 2796396
I got iPad 5th Gen 2017 use nand pcie
Old 06-07-2018, 07:58   #12 (permalink)
Member: 2695394
iPad mini 1 compatibility which can I change
Old 06-07-2018, 09:07   #13 (permalink)
Member: 2277735
Thanks Meter: 215
Ipads convert to wifi only and change nand or serial, and macs with nand programer... Iphone 7,8,x and ipad pros have new nands so pins are different, you need a different nand programer that has to correct pin out for the new nands!
Navi plus 3000s for 32 bit and 64 bit nands
New (6s?)7,8,x pros need an PCIE nand programer
PS: anyone have clean Ipad 4 (seiral and macs) details as need to activate facetime and imessinger! can pay no problem!!
Old 06-09-2018, 00:18   #14 (permalink)
Member: 2277735
Thanks Meter: 215
Dont swap nands as giroscope dos not work, reprogram nand only!
Old 06-20-2018, 22:01   #15 (permalink)
Member: 2826478
iPad 4 iPhone 5
iPad mini 3 gen
iPad mini 4 gen
I used iphone6 on ipad air 1st gen and it wouldnt activate as it was waiting for me to insert a sim card?
Page generated in 0.21428 seconds with 9 queries
