12-26-2020, 06:41 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: belgium
Member: 93210 Status: Offline Thanks Meter: 12 | Tbk 958b files MANUAL DRAWING 24/12/20 (iPhone 12 INCLUDE) add moore language Admin password 111111 source here Last edited by devilcorp; 12-26-2020 at 06:49. |
The Following 2 Users Say Thank You to devilcorp For This Useful Post: |
12-26-2020, 06:44 | #2 (permalink) |
Member: 93210 Status: Offline Thanks Meter: 12 | changelog: 3.1.69.11 1. [Two-dimensional split marking] to increase the overall calculation of the group; 2. [Tools] menu to add view character stream communication protocol description; 3. [Database record marking 】Change to 【Server record marking】, and add expense json data analysis; 4. Fix 【Pen number group marking】restart problem when marking group content; 5. Fix when the about page displays the manufacturer logo There is a problem with the abnormal position of the QR code; 6. [Tools] menu adds the function of serial number generation database; 3.1.69.09 1. [IO configuration] add the positive limit detection and correction of the extended axis ; 2. Independent the configuration interface in the [extension axis configuration and debugging] to [Settings] ->[Extended Axis Parameter Configuration] interface; 3. Add more than 5 errors when starting up, prompting the customer to return to the factory for repair; 4. [Multi-document marking] and [Pen number grouping marking] marking completion output time and [IO Configured to share the marking completion output time; 3.1.69.07 1. [SN barcode registration MES] module to optimize task number permissions; 3.1.69.05 1. Red light preview adds rotation axis movement debugging; 2. Edits and adds path shaping functions (trimming, welding, crossing); 3. [Multi-card marking] added Mark all or only the functions of the currently selected board; 4. Optimize the root directory of the USB flash drive and no firmware prompt is found (use manual firmware upgrade); 5. Fix the [Event Manager] output port action before the input port action appears Failure problem 3.1.69.03 1. Optimize font editor; 2. Combine text/barcode to increase network communication; 3. Add pen number parameter [integral calculation of marking times]; 4. Event manager module Add the action of [New Input Port]; 5. One-key backup and restore file name with default date added; 6. Optimize cutting action; |
The Following 3 Users Say Thank You to devilcorp For This Useful Post: |
08-25-2022, 16:06 | #7 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Dominican Republic
Member: 1607116 Status: Offline Sonork: 100.1617729 Thanks Meter: 52 | iPhone 13 back http://shenwangda.com/h-col-137.html (iPhone 13 INCLUDE) |
06-28-2023, 21:54 | #10 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Argentina
Member: 1914674 Status: Offline Sonork: 100.1652329 Thanks Meter: 41 | I found the latest version: 3.1.74.61 DATE: 2023-06-19 CHANGELOG Quote:
