iphone 2g earpiece not working hi i have a small problem in here , need some ideas from iphone pro. earpiece and mic not working on call , when i change to speaker call the mic starts working ... (not a frimware issue) i have open the iphone , changed earpiece , same problem. i now have changed the special flat cable conecting the earpiece to the iphone , at start it was working , also i have put it only for testing , so it was not in place. after i have fixed all in place , problem back again. when i testing direct conection between earpiece and flat conector , there is a conection going to the iphone from earpiece points .... so its something else making this problem ideas ? |
o.k guys after some testing .... its the power key and volume flex cable make this problem |
ive got the same problem with a iphone, can you tell me where you get the parts from please? |
I have this same problem, but the mic and the earpiece work only when I plug the handfree auricular. |
have u any solution for this |
any body find this problam solution sand it |
replce power cable have done and myne is ok |
