Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-26-2010, 16:21   #151 (permalink)
Member: 1219539
Hi All, great info here... I have a problem with the LCD connector on the logic board - that receives cable number 1.
If you're looking at the phone the right way up, with the connector on the top right hand side, the pin on the top row at the far right hand side has broken off.
Can anyone tell me what this pin does on the LCD display?
I think it may be the backlight to the LCD as the screen now has no backlight - however i'm not 100% sure the LCD is working correctly either so i'd like to know if anyone knows for sure what this pin does?
Also, to fix the solution, could i crudely put a piece of solder onto the remains of the pin on the logic board, to make the connection to the plug on cable number 1? Or is ist a simple de-solder the whole connector and resolder a new one? [by the way - i wouldnt be the best solderer in the world!! ]
Thanks in advance for any suggestions.
Old 01-27-2010, 15:13   #152 (permalink)
Member: 299902
Thanks Meter: 20
l have the same problem but the bottom right row and its the second pin also l have no back light now lm not sure if your problem or my problem is the couse of the light problem or its some other problrm
Old 01-27-2010, 21:09   #153 (permalink)
Member: 1220688
Red face 3g problem
took phone to have home button replaced after which the phone came back and now does not power up unless attached to ac adapter and computer does not recognise ..i should say by power up on ac i mean it shows apple logo for ten seconds and then shuts off but can see a dimmed logo for a while ..phone was working perfectly until tech went inside ..tried the power and home button then but no luck ,tried the a method of flicking mute button 4 times and then power and home button press no luck. i can see lines like phone is trying to boot ..
any help or ideas would be appreciated ..
Old 01-28-2010, 00:21   #154 (permalink)
Member: 1220645
running out of ideas how to recover my iphone..
the other day it said "no service" when i woke up, waited, nothing happened, finally decided to reset it.. and it's just been resetting ever since. took it to the genius bar also, they claim it's bricked (prolly because they saw my tmobile sim card in the phone instead of the at&t, and they realize it's bee jail broken).
even took it apart to look around, and put it back together (sometimes that fixes minor issues with some electronics).. but same problem persists!
would really like to backup my current data or get access to it somehow.. i'm considering getting a broken-screen iphone and maybe doing a transplant on the memory chip?? i know how to solder a little but the small size of the chip connects is a little daunting so i would rather not try (if it comes to that, does anyone have any advice??).. hmm, not even sure how to get the metal shield off the display side of the logic board
so far, iTunes doesn't see the phone (unless i boot it to recovery mode).. is there a way to force a backup of the data in recovery mode perhaps??
plz help
Old 01-29-2010, 07:47   #155 (permalink)
Member: 697232
Pls help! I accidentally droped my iphone 3g , now the backlight was gone! But I can still see the icons and use it. Only problem is the backlight ?! What could be the possible problem? I just recognized lately that when i shake my phone I heard sound in a specific area, as if there was diconnected part or cable ? pls help.
Old 01-29-2010, 13:40   #156 (permalink)
Member: 1219539
Cell2Cell - Did you find out if it was the pin or another problem causing the loss of the backlight?
Old 01-29-2010, 14:56   #157 (permalink)
=GsM_Angel='s Avatar
Member: 1062107
Thanks Meter: 544
here' a big help for your search.... all the Chips Schematics Diagram
Apple Iphone 3G and 3GS IC Parts Datasheets(Component Schematic Diagram and Info)
For Hardware Pro's and Advance troubleshooter's Guide
3G
3GS
SST SST25VF080B 1 MB SERIAL FLASH
http://www.alldatasheet.com/datashee...T25VF080B.html
Samsung ARM-based CPU (markings: 339S0036 ARM EMC567DB 819 8900B N182F0A3 0825 7511.101 ZPD8163Y)
with DDR SDRAM Samsung
http://datasheet.octopart.com/K4X1G1...eet-472067.pdf
ST MICROELECTRONICS LIS331 DL ACCELEROMETER
http://datasheetz.com/ST/13951/13951.html
INFINEON SMP3i SMARTi POWER MANAGEMENT IC
http://www.infineon.com/cms/en/produ...19ebec03f05327
Skyworks SKY77340 Power Amp. Module (824-915 MHz Power Amplifier Module Quad)
http://www.datasheetpro.com/425257_d...datasheet.html
Infineon PMB 6952 UMTS Transciever
http://infineon.com/cms/en/product/c...12ab6ac4b80611
Triquint TQM676031 WCDMA/HSUPA power amp
An integrated 3-V linear UMTS Band 1 power amplifier (PA),
duplexer and transmit filter module, with output power detector.
It supports HSUPA operation with transmission data-rates up to 10 Mbits/s.
http://www.triquint.com/docs/o/TQM676021/tqm676021.pdf
Triquint TQM666032 WCDMA/HSUPA power amp
Similar like TQM676031, but for Band 2 operation.
http://www.triquint.com/docs/o/TQM666022/tqm666022.pdf
Triquint TQM616035 WCDMA/HSUPA power amp
WCDMA/HSUPA PA-duplexer module for Band 5 and 6.
datasheet unavailable
Numonyx PF38F3050M0Y0CE 16 MB NOR Flash - 8 MB Pseudo-SRAM
http://www.numonyx.com/Documents/Mar...ORwireless.pdf
Infinieon Digital Baseband Processor
NXP Power management
http://people.openmoko.org/tony_tu/G...50633DS_02.pdf
Linear Technology LTC4088-2 Battery charger/USB controller
http://cds.linear.com/docs/Datasheet/40881fb.pdf
Infineon PMB2525 Hammerhead II GPS
http://www.datasheetdir.com/PMB2525+GPS
Wolfson WM6180C Audio Codec
http://www.wolfsonmicro.com/productListings/codecs
Broadcom BCM5974 Touchscreen controller
no datasheets available
NATIONAL SEMICONDUCTOR LM2512AA DISPLAY INTERFACE
http://www.national.com/ds/LM/LM2512A.pdf
Toshiba TH58G6D1DTG80 8GB Flash (8GB model!)
Marvell 88W8686 WiFi
http://www.pdf-search-engine.com/88w8686-pdf.html
CSR BlueCore6-ROM Bluetooth
http://downloads.openmoko.org/develo...2520Issue1.pdf
original link:
http://forum.gsmhosting.com/vbb/showthread.php?t=906068
The Following 5 Users Say Thank You to =GsM_Angel= For This Useful Post:
Old 02-01-2010, 09:30   #158 (permalink)
Member: 732715
Hi all,
I'm loosing 2G signal on my iPhone 3G 16gb black, so what part of motherboard should i look for? I have already dissasembled it.
Thank you in advance,
Mursel
Old 02-01-2010, 09:33   #159 (permalink)
Registered User
mansu03's Avatar
Member: 1197853
Sonork: 100.200.003
Thanks Meter: 18
where can i get iphone 3g motherboard diagram?
Old 02-01-2010, 20:06   #160 (permalink)
Member: 1224858
Thanks Meter: 6
Solder Pad on iphone sim card broken
Hi,
I've just been given a 3G iphone by a friend. He put the sim card tray in the wrong way round and broke some of the ***** pins. He therefore got a replacement part to solder on, but whilst removing the old connector he also managed to remove the solder pads from the PCB, so that there's now nothing to solder it to. Does anyone have any knowledge if there's somewhere else to pick up these connections on the logic board?
Thanks
Old 02-01-2010, 20:13   #161 (permalink)
Member: 1224858
Thanks Meter: 6
Originally Posted by nafg View Post
iphone 3g sim problem solution
http://forum.gsmhosting.com/vbb/atta...5&d=1244821357
br
nafg
My problem with the removed solder pad was discussed back at the beginning of this thread and some people attempted to answer it, but I am a bit lost.
In the above image I am missing the pad for the blue connection. Does anyone know if this edited image refers to the iphone 3G as I can't find anywhere that looks like the embedded image to link it to...
Old 02-01-2010, 20:36   #162 (permalink)
Member: 1220688
Red face
Originally Posted by angelz9 View Post
took phone to have home button replaced after which the phone came back and now does not power up unless attached to ac adapter and computer does not recognise ..i should say by power up on ac i mean it shows apple logo for ten seconds and then shuts off but can see a dimmed logo for a while ..phone was working perfectly until tech went inside ..tried the power and home button then but no luck ,tried the a method of flicking mute button 4 times and then power and home button press no luck. I can see lines like phone is trying to boot ..
Any help or ideas would be appreciated ..
help please .....just a little help
Old 02-01-2010, 21:22   #163 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
yes is iphone 3g is at backside under radiation graphite sheet
br
nafg
Old 02-02-2010, 16:57   #164 (permalink)
Member: 1224858
Thanks Meter: 6
br
nafg
Thanks for confirming it is the 3G model of the phone. I have removed the graphite sheet and now am faced with a PCB which looks identical to the one shown here http://s2.guide-images.ifixit.com/ig...1YVQh2IW.large . I would be very grateful if someone could show the correlation between this image and the previous one from nafg. If someone could highlight where the various colour-coded points connect to from the original image...
Old 02-02-2010, 18:14   #165 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
hi solution sim thank for pic
br
nafg
The Following 3 Users Say Thank You to nafg For This Useful Post:
iPhone 3G S Diagram Here delower10 iPhone, iPad, iPod Hardware Repair 11 12-27-2010 14:57
IPhone 3g broken motherboard no service Farntet iPhone 4 / iPhone 4S 4 11-25-2010 11:51
iphone 3G MotherBoard Diagram------By {{{Rasel--Wingstel--Bangladesh}}} Wingstel iPhone 2 / iPhone 3G / iPhone 3GS 4 01-27-2010 12:26
iPhone 3G S Motherboard Diagram by parts Zulea II iPhone 2 / iPhone 3G / iPhone 3GS 0 11-23-2009 08:03
Page generated in 0.25091 seconds with 10 queries
