10-19-2010, 13:18 | #337 (permalink) |
Crazy Poster Join Date: Dec 2009
Member: 1190812 Status: Offline Thanks Meter: 17 | iphone 3Gs no signal Hi all...i have an iphone 3Gs with no signal problem. I check the antenna circuit with tester and i noticed that these points are connected to ground, i think that it shouldnt' be like these. So i try to rehot the antenna switch but i havn't any result. I would ask to someone who has more experience if i have to replace antenna switch or if the problem colud be solved with another solution. thanks and sorry for my bad english |
10-20-2010, 18:17 | #338 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Cracow
Member: 739941 Status: Offline Thanks Meter: 111 | signal on antena socket almost ground, you can see coil near antena socket GND----coil---antena---coil--------signal(switch) If no signal gsm replance switch or PA |
The Following User Says Thank You to artusb For This Useful Post: |
10-21-2010, 21:59 | #339 (permalink) | |
Member: 1190812 Status: Offline Thanks Meter: 17 | Quote:
who lend me these phone say to me that the gsm signal decrease slowly in the last 2-3 month until it get No services. | |
10-25-2010, 06:39 | #341 (permalink) | |
Junior Member Join Date: Oct 2010
Member: 1425955 Status: Offline Thanks Meter: 0 | Quote:
Hi everyone. I have the exact same problem, but when I took off the metal part to see how was looking what is under, everything looks perfectly fine. Is there a way to check that those parts are good or not (testing the resistance maybe). Any other thing that I could check ? Many thanks | |
10-30-2010, 15:59 | #343 (permalink) |
Member: 1425955 Status: Offline Thanks Meter: 0 | My "fuse" looks in great shape, still does that mean that replacing it will solve my probleme for sure ? My digitizer is not working either is there a link between thos two problems ? Last question, where can I find a replacing part and what is its reference ? Many Thanks |
11-05-2010, 16:45 | #344 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1435907 Status: Offline Thanks Meter: 0 | Hi all, my iphone3G don't charge anymore and it is not recognize by itunes. Only black screen It 's history : following Wifi problem i have reflow the wifi chip and eveything work good. Until the full discharge of the battery. My phone go off and since never wake up again. I have check the USB controler voltage and have 5V on all point marked. Somebody can help me please? |
11-05-2010, 20:34 | #345 (permalink) | |
Freak Poster Join Date: Sep 2002 Location: Aussie Age: 54
Member: 15355 Status: Offline Thanks Meter: 4 | Quote:
got a 3g here with this problem, the pcb is cracked from outter edge screw hole and phone works but has no signal, although the pcb is multi layer if this corner was removed to stop layers shorting would it then be possible to link the antenna switch to the antenna and restore service. anybody any thoughts on this or tried it befor. | |
iPhone 3G S Diagram Here | delower10 | iPhone, iPad, iPod Hardware Repair | 11 | 12-27-2010 14:57 |
IPhone 3g broken motherboard no service | Farntet | iPhone 4 / iPhone 4S | 4 | 11-25-2010 11:51 |
iphone 3G MotherBoard Diagram------By {{{Rasel--Wingstel--Bangladesh}}} | Wingstel | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-27-2010 12:26 |
iPhone 3G S Motherboard Diagram by parts | Zulea II | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 11-23-2009 08:03 |
