03-17-2013, 18:21 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Age: 39
Member: 475448 Status: Offline Thanks Meter: 60 | 3gs reball baseband is.... failed...why? What i did wrong? - i remove around the ic the black gue with small heat and with dental pick - I made heating tape around the IC - i heated the ic... - then i can pull the IC up, but some pads stay on the ic.. - i see under microscope, on the ic and on the board is full black glue, how can i remove? i used flux, but some pads are going from board, when i solder the pads... i can't belive, any ic with too much pins can anybody reball, or what do i wrong???? |
03-17-2013, 18:58 | #2 (permalink) |
Junior Member Join Date: May 2012
Member: 1757890 Status: Offline Thanks Meter: 4 | maybe, did not have the temperature, and compound or solder wasn't melt. Did you use flux? Flux also plays a large role, when you reballing/removed/installing IC. Basically, i'm using 345-355 degress temperature, In extreme or rare event, it came to 380 degrees, but there is a risk of overheating and damage the element. |
The Following User Says Thank You to dekuort For This Useful Post: |
03-17-2013, 19:02 | #3 (permalink) |
Member: 1757890 Status: Offline Thanks Meter: 4 | P.S. This IC very hard to be removed. If you have a dead motherboard 3g/3gs with baseband or other elements with compound, advice from me: traning, and traning. I learned this a long time, and that is tear off pads. |
03-18-2013, 03:23 | #4 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1891566 Status: Offline Thanks Meter: 1 | Im also practicing for this. I found that flux also help to soften the black glue. But it takes time. A long time. First i use 180c of heat with flux. Then leave the board for a few hours. Then reheat at 180c then use 320c to remove the ic successfully. Still need to practice a lot on this because so far i use a tweezer to hold the ic and try to wiggle it while it got heat up by the heat gun. In one case i actually cracked the ic because use too much force |
