06-01-2014, 07:35 | #1 (permalink) |
Junior Member Join Date: Nov 2008 Location: phillipines
Member: 908365 Status: Offline Sonork: 100.1617948 Thanks Meter: 2 | iphone 4s blank dfu mode only HELP!.. ill try to restore it in 7.1.1 version and flashing completed then reboot itself back to blank dfu mode again..nothing to display just only black display on iphone 4s then connect again to itunes and restore it again. may be it is a hardware failure, please help. Thanks in advance |
06-01-2014, 07:58 | #2 (permalink) |
Super Moderator Join Date: Dec 1999 Location: In EveryOne's Heart
Member: 824 Status: Offline Thanks Meter: 25,150 | IF your software successfully complete then simply change the LCD and then tell me... or use other LCD Pannel |
The Following User Says Thank You to mihut For This Useful Post: |
06-01-2014, 08:36 | #4 (permalink) | |
Member: 908365 Status: Offline Sonork: 100.1617948 Thanks Meter: 2 | Quote:
06-01-2014, 08:36 | #5 (permalink) | |
06-01-2014, 10:01 | #7 (permalink) | |
06-01-2014, 10:04 | #8 (permalink) |
Member: 824 Status: Offline Thanks Meter: 25,150 | than its hardware problem.. replace the charging jeck and then try its hardware problem not a software |
06-01-2014, 10:23 | #9 (permalink) | |
06-01-2014, 10:45 | #10 (permalink) | ||
please need another solutions.. | ||
06-01-2014, 11:02 | #12 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76257 Status: Offline Thanks Meter: 77 | if there is no progress bar coming while restoring but software is loading ok according to itunes then its the components near the lcd jack that r water logged or broken or may be its the no lcd light issue thats it. |
06-01-2014, 15:24 | #15 (permalink) | |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Quote:
are you sure your phone is still dfu mode i think not.....ok open itunes and power on your iphone wait lilbit now connect your phone to pc carefully see the itunes detection massage if itunes say that iphone is connected in recovery mode and need to restore that means you are write or if phone connect normaly in itunes than you are wrong as you already try change lcd also then u should try lcd light repair hare is it try this 4s lcd light solution | |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
