Iphone 4S blankscreen after wifi module changed Phone is working, can receive calls, itunesc recognize phone, but blankscreen. Need some help, please! Wifi and bluetooth not working, so i replaced USI 339S0154 ic. After that, ic goes hot, so i removed it and now still blankscreen. |
Check using microscope components near lcd connector.. I believe that you accidently removed at least one of them or damaged tracks on board.. |
Checked 5 times. All components there :( |
I have the same problem. http://forum.gsmhosting.com/vbb/f631...creen-1846651/ Maybe not all of your wifi pins have contact. I don't think I overheated the CPU. |
Tried again with the old chip. Result: if i press harder on wifi chip, screen goes ON |
So you get apple logo and iOS screen with soldered wifi chip? |
Yes, that's right! One more thing: the CPU is combined by two pieces and i have just the bottom one, i mounted back on mainboard and the display is fine. |
Resolder the lcd connector anyway, it may look fine, but not connecting enough. are you using heat gun under the wifi? |
What do you mean with the CPU is combined by two pieces? Did you remove and reball the a5 processor? I'm waiting for a new wifi chip. Like you said, when wifi is soldered back properly the screen should work again right? Without wifi chip or incorrect soldered wifi, screen stays black!? |
CPU = wifi chip. this chips have two layers... I will post some photos after i charge the camera battery. |
I can guarantee that this 4S won't display anything, but backlight after removed wifi module. |
Like my 4s...no Screen without wifi Module. |
