iPHone 4s boot loop with logo - battery not recgnized HI, I have iphone 4s that: 1. only powers on fine when plugged into wall outlet. 2. does a boot loop with logo when plugged into the usb port on pc. Not recognized by iTunes. when this happens, I do a reset holding down power and home button. i get the connect to pc icon on phone, but then iTunes sees it for a second as I try to restore device, once it begins to access the device, it fails with 2001 error. Then back to boot loop with logo. I looked under microscope and it seems the diodes and the battery connector are on pretty solid. 3. battery is fine. I have 3 good ones i used to test. Can you help? |
and check also the battery connector with ur tester if shorted or not |
yes water damage. I checked the battery connector - I checked and there was continuity from the pins to the 4 diodes as per a schematic I saw.... What can I check next? the logic board gets very hot during boot loop. Thanks |
First check short between + and - on battery connector. |
I checked between pin 1 and 4 on the battery connector J9 and there is continuity, so that is bad, what can I try next? Thanks for helping. |
Is it shorted?? 0 ohm?? |
multimeter set on beep continuity test, OHM reading showing 007 with beep. I tested with good 4s board showing no beep and 1505 in ohm setting. |
is this right? please help with next thing to try with multimeter and I have schematics, thanks. |
I just noticed the logic board is missing: DZ7, C152 and R105 would this cause problem? Thanks |
http://i1288.photobucket.com/albums/...psedpzvsol.jpg |
bro check this hope it can help u gudluck http://i1288.photobucket.com/albums/...ps01f94b30.jpg |
