06-19-2013, 20:28 | #1 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1963115 Status: Offline Thanks Meter: 1 | power management ic Hi people im new on here and new to fixing phones really. iv got a iphone 4 has no life at all, put a working battery in and charger still nothing the power ic gets warm too. iv tried to disconnected everything to see if it was the screen ect but made no difference. just looking for advise really what i should check. cheers simon. |
06-20-2013, 02:39 | #2 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Toronto, Canada
Member: 1430995 Status: Offline Sonork: 100.1613203 Thanks Meter: 312 | Check + and - terminal for short. If not then change PMIC. |
The Following User Says Thank You to cal_guy For This Useful Post: |
06-23-2013, 05:32 | #5 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Brisbane, Australia
Member: 1788854 Status: Offline Sonork: Mobile Fix Simple Thanks Meter: 16 | Preheat the board, heat the glue and use cutter to clear the glue slowly. After the glue is clear, heat the chip and use a tiny tip or cutter to lift up the chip, give the chip with a GENTLE LIFT SLOWLY, otherwise the pins under the chips will be broken. |
07-09-2013, 09:54 | #8 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Wikon, Switzerland
Member: 1012778 Status: Offline Thanks Meter: 245 | Before changing any IC: Check if one of the Outputs are shorted! The PMIC get's hot in this case! Also check if the PP1V35 and PP1V8_SDRAM going up and go back to 0V after pressing the power button for 0.5sec and release it after. If the voltages stay, check for Shorts at the Output first. I've had only 5 times that the PMIC on a 4 was bad after more than 700 repairs! |
The Following User Says Thank You to kostelectronics For This Useful Post: |
07-10-2013, 14:57 | #9 (permalink) |
Junior Member Join Date: May 2013
Member: 1930818 Status: Offline Thanks Meter: 0 | i have iphone 4 .... it has no life ...but when i connect it on charging the red charging logo comes on screen but the iphone is not charging at all and pmic is getting very hot and hot ...i tried to replace the battery but then also same problem continuess.....what might be the problem |
07-12-2013, 14:29 | #12 (permalink) |
