Iphone 4S -> iTunes Error 4014 -> restoring not possible I baught an iPhone 4S 16GB. The history of the Phone is unfortunally not 100% sure. All I know is, that the iPhone was dropped and got a Touchscreen damage. The previous owner told me that only the touchscreen did not react. All other funktions were 100% ok. After he changed the display the problem began: IPhone did not start. No Picture. No Sound. Itunes didn't recognized phone. That is all i know about the history. I put the iPhone in DFU mode and iTunes found an iPhone in recovery mode. Unfortunally restoring ends with error 4014. That is all I have done until now: 1.) iTunes update to newest version 2.) Windows XP update 3.) used 4 different USB cords (2 original, 2 not original) 4.) changed dock-connector twice 5.) used 3 different batteries (1 brand new) 6.) tried restoring with and without connected flexcables (cams, sensor/ audio) 7.) bought a new notebook with win 7 and tried it 100x ;) 8.) checked logicboard with microscope. No liquid damage. No corrosion. No obviously damaged parts 9.) checked board with beeper. No short found. 10.) disabled virusscan and firewall 11.) checked host data I think that it is a hardware failure after a fall on the floor or bad repair from previous owner. But what do I have to look for? Error 4014 means (as I know) that there is an interruption of the connection. Could it be the nand chip? I'd appreciate meaningful assistance from professionals very much. |
After changing the battery again by using an used but absolutely original Apple Battery there is a new behaviour of iTunes: Now the procedere ends with :...Waiting for iPhone No error code. The apple appears on iPhones display with an empty statusbar. Only by pulling the USB cable i can interrupt this. Answering from iTunes with Error 9 (of course). Here are the logfiles i found: 2014-07-06 17:57:10.521 [6040:6a0]: restore library built Feb 12 2014 at 16:27:17 2014-07-06 17:57:10.521 [6040:6a0]: iTunes: iTunes 11.2.2.3 2014-07-06 17:57:10.521 [6040:6a0]: iTunes: Software payload version: 11D257 2014-07-06 17:57:10.521 [6040:6a0]: iTunes: Using MobileRestore state machine [15:58:19.0380] Changing state from 'Idle' to 'Restoring' [15:58:19.0380] device software does not support nonce generation [15:58:19.0380] requested restore behavior: Erase [15:58:19.0395] requested variant: Erase [15:58:19.0395] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 0CC65528 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 0CC65600 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 06927C88 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>} [15:58:20.0191] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled. [15:58:20.0191] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per6125.tmp/amai/debug/tss-request.plist [15:58:20.0456] amai: tss_submit_job: HttpQueryInfo returned 200 [15:58:20.0581] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) [15:58:20.0581] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per6125.tmp/amai/debug/tss-response.plist [15:58:20.0628] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" [15:58:20.0643] <DFU Device 067DD2B8>: production fused device [15:58:20.0643] requested restore behavior: Erase [15:58:20.0643] device software does not support nonce generation [15:58:20.0643] WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ab93d329 [15:58:20.0643] WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ab93d329 [15:58:20.0659] <DFU Device 067DD2B8>: operation 0 progress 2 [15:58:20.0675] <DFU Device 067DD2B8>: operation 0 progress 5 [15:58:20.0690] <DFU Device 067DD2B8>: operation 0 progress 8 [15:58:20.0706] <DFU Device 067DD2B8>: operation 0 progress 10 [15:58:20.0721] <DFU Device 067DD2B8>: operation 0 progress 13 [15:58:20.0737] <DFU Device 067DD2B8>: operation 0 progress 16 [15:58:20.0753] <DFU Device 067DD2B8>: operation 0 progress 18 [15:58:20.0768] <DFU Device 067DD2B8>: operation 0 progress 21 [15:58:20.0784] <DFU Device 067DD2B8>: operation 0 progress 24 [15:58:20.0799] <DFU Device 067DD2B8>: operation 0 progress 26 [15:58:20.0815] <DFU Device 067DD2B8>: operation 0 progress 29 [15:58:20.0831] <DFU Device 067DD2B8>: operation 0 progress 32 [15:58:20.0846] <DFU Device 067DD2B8>: operation 0 progress 34 [15:58:20.0862] <DFU Device 067DD2B8>: operation 0 progress 37 [15:58:20.0877] <DFU Device 067DD2B8>: operation 0 progress 40 [15:58:20.0893] <DFU Device 067DD2B8>: operation 0 progress 42 [15:58:20.0909] <DFU Device 067DD2B8>: operation 0 progress 45 [15:58:20.0924] <DFU Device 067DD2B8>: operation 0 progress 48 [15:58:20.0940] <DFU Device 067DD2B8>: operation 0 progress 50 [15:58:20.0955] <DFU Device 067DD2B8>: operation 0 progress 53 [15:58:20.0971] <DFU Device 067DD2B8>: operation 0 progress 56 [15:58:20.0987] <DFU Device 067DD2B8>: operation 0 progress 59 [15:58:21.0002] <DFU Device 067DD2B8>: operation 0 progress 61 [15:58:21.0018] <DFU Device 067DD2B8>: operation 0 progress 64 [15:58:21.0033] <DFU Device 067DD2B8>: operation 0 progress 67 [15:58:21.0049] <DFU Device 067DD2B8>: operation 0 progress 69 [15:58:21.0065] <DFU Device 067DD2B8>: operation 0 progress 72 [15:58:21.0080] <DFU Device 067DD2B8>: operation 0 progress 75 [15:58:21.0096] <DFU Device 067DD2B8>: operation 0 progress 77 [15:58:21.0111] <DFU Device 067DD2B8>: operation 0 progress 80 [15:58:21.0127] <DFU Device 067DD2B8>: operation 0 progress 83 [15:58:21.0143] <DFU Device 067DD2B8>: operation 0 progress 85 [15:58:21.0158] <DFU Device 067DD2B8>: operation 0 progress 88 [15:58:21.0174] <DFU Device 067DD2B8>: operation 0 progress 91 [15:58:21.0189] <DFU Device 067DD2B8>: operation 0 progress 93 [15:58:21.0205] <DFU Device 067DD2B8>: operation 0 progress 96 [15:58:21.0221] <DFU Device 067DD2B8>: operation 0 progress 99 [15:58:21.0221] WinDFU::UploadData: EOF, cbRead: 554 [15:58:21.0236] <DFU Device 067DD2B8>: operation 0 progress 100 [15:58:21.0236] WinDFU::UploadData: ZLP [15:58:21.0252] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [15:58:21.0252] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [15:58:21.0252] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [15:58:21.0252] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [15:58:24.0263] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [15:58:24.0263] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [15:58:24.0263] WinDFU::ResetDevice: resetting... [15:58:24.0341] WinDFU::FinalizeDfuUpdate: success [15:58:24.0341] <DFU Device 067DD2B8>: DFU succeeded [15:58:24.0341] Finished DFU Restore Phase: Successful [15:58:24.0559] DFU mode device disconnected [15:58:24.0559] Device removed when in state Restoring, moving device to transition state [15:58:24.0559] Changing state from 'Restoring' to 'Transitioning' [15:58:24.0559] Creating timer to monitor transition [15:58:25.0654] DFU mode device connected [15:58:25.0655] Transitioning device returned, continuing restore. [15:58:25.0655] Canceling timer [15:58:25.0656] Changing state from 'Transitioning' to 'Restoring' [15:58:25.0657] AppleDevice::GetDeviceID: failed for iBoot [15:58:25.0658] requested restore behavior: Erase [15:58:25.0658] requested variant: Erase [15:58:25.0659] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:26.0452] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is True [15:58:26.0452] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreLogo" Digest = "<CFData 05BF5CF8 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDeviceTree" Digest = "<CFData 05BF4438 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreKernelCache" Digest = "<CFData 0CCC09F0 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreRamDisk" Digest = "<CFData 0CCC0960 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 0CCC0A80 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 0CCC0A38 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "KernelCache" Digest = "<CFData 0CCC0918 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow1" Digest = "<CFData 0CCC0B10 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow0" Digest = "<CFData 0CCC09A8 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 0CCC08D0 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBoot" Digest = "<CFData 0CCC0888 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DeviceTree" Digest = "<CFData 0CC8A980 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging1" Digest = "<CFData 0CC8A6B0 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AppleLogo" Digest = "<CFData 0CC8A8F0 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryPlugin" Digest = "<CFData 0CC8A668 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryFull" Digest = "<CFData 0CC8A6F8 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging0" Digest = "<CFData 0CC74E20 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0483] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RecoveryMode" Digest = "<CFData 0CC74F40 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0483] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 069258E8 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>} [15:58:26.0483] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled. [15:58:26.0483] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per6125.tmp/amai/debug/tss-request.plist [15:58:26.0639] amai: tss_submit_job: HttpQueryInfo returned 200 [15:58:26.0780] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) [15:58:26.0780] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per6125.tmp/amai/debug/tss-response.plist [15:58:26.0780] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "iBSS" has been previously personalized; skipping it [15:58:26.0795] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "LLB" has been previously personalized; skipping it [15:58:26.0795] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" [15:58:26.0811] <DFU Device 01F3B8D8>: production fused device [15:58:26.0811] requested restore behavior: Erase [15:58:26.0827] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:26.0827] AppleDevice::GetDeviceID: failed for iBoot [15:58:26.0827] WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ce671dc7 [15:58:26.0827] WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ce671dc7 [15:58:26.0858] <DFU Device 01F3B8D8>: operation 0 progress 0 [15:58:26.0873] <DFU Device 01F3B8D8>: operation 0 progress 1 [15:58:26.0889] <DFU Device 01F3B8D8>: operation 0 progress 2 [15:58:26.0920] <DFU Device 01F3B8D8>: operation 0 progress 3 [15:58:26.0936] <DFU Device 01F3B8D8>: operation 0 progress 4 [15:58:26.0951] <DFU Device 01F3B8D8>: operation 0 progress 5 [15:58:26.0983] <DFU Device 01F3B8D8>: operation 0 progress 6 [15:58:26.0998] <DFU Device 01F3B8D8>: operation 0 progress 7 [15:58:27.0029] <DFU Device 01F3B8D8>: operation 0 progress 8 [15:58:27.0045] <DFU Device 01F3B8D8>: operation 0 progress 9 [15:58:27.0061] <DFU Device 01F3B8D8>: operation 0 progress 10 [15:58:27.0092] <DFU Device 01F3B8D8>: operation 0 progress 11 [15:58:27.0107] <DFU Device 01F3B8D8>: operation 0 progress 12 [15:58:27.0123] <DFU Device 01F3B8D8>: operation 0 progress 13 [15:58:27.0154] <DFU Device 01F3B8D8>: operation 0 progress 14 [15:58:27.0170] <DFU Device 01F3B8D8>: operation 0 progress 15 [15:58:27.0201] <DFU Device 01F3B8D8>: operation 0 progress 16 [15:58:27.0217] <DFU Device 01F3B8D8>: operation 0 progress 17 [15:58:27.0232] <DFU Device 01F3B8D8>: operation 0 progress 18 [15:58:27.0263] <DFU Device 01F3B8D8>: operation 0 progress 19 [15:58:27.0279] <DFU Device 01F3B8D8>: operation 0 progress 20 [15:58:27.0295] <DFU Device 01F3B8D8>: operation 0 progress 21 [15:58:27.0326] <DFU Device 01F3B8D8>: operation 0 progress 22 [15:58:27.0341] <DFU Device 01F3B8D8>: operation 0 progress 23 [15:58:27.0373] <DFU Device 01F3B8D8>: operation 0 progress 24 [15:58:27.0388] <DFU Device 01F3B8D8>: operation 0 progress 25 [15:58:27.0404] <DFU Device 01F3B8D8>: operation 0 progress 26 [15:58:27.0435] <DFU Device 01F3B8D8>: operation 0 progress 27 [15:58:27.0451] <DFU Device 01F3B8D8>: operation 0 progress 28 [15:58:27.0466] <DFU Device 01F3B8D8>: operation 0 progress 29 [15:58:27.0497] <DFU Device 01F3B8D8>: operation 0 progress 30 [15:58:27.0513] <DFU Device 01F3B8D8>: operation 0 progress 31 [15:58:27.0544] <DFU Device 01F3B8D8>: operation 0 progress 32 [15:58:27.0560] <DFU Device 01F3B8D8>: operation 0 progress 33 [15:58:27.0575] <DFU Device 01F3B8D8>: operation 0 progress 34 [15:58:27.0607] <DFU Device 01F3B8D8>: operation 0 progress 35 [15:58:27.0622] <DFU Device 01F3B8D8>: operation 0 progress 36 [15:58:27.0638] <DFU Device 01F3B8D8>: operation 0 progress 37 [15:58:27.0669] <DFU Device 01F3B8D8>: operation 0 progress 38 [15:58:27.0685] <DFU Device 01F3B8D8>: operation 0 progress 39 [15:58:27.0716] <DFU Device 01F3B8D8>: operation 0 progress 40 [15:58:27.0731] <DFU Device 01F3B8D8>: operation 0 progress 41 [15:58:27.0747] <DFU Device 01F3B8D8>: operation 0 progress 42 [15:58:27.0778] <DFU Device 01F3B8D8>: operation 0 progress 43 [15:58:27.0794] <DFU Device 01F3B8D8>: operation 0 progress 44 [15:58:27.0809] <DFU Device 01F3B8D8>: operation 0 progress 45 [15:58:27.0841] <DFU Device 01F3B8D8>: operation 0 progress 46 [15:58:27.0856] <DFU Device 01F3B8D8>: operation 0 progress 47 [15:58:27.0887] <DFU Device 01F3B8D8>: operation 0 progress 48 [15:58:27.0903] <DFU Device 01F3B8D8>: operation 0 progress 49 [15:58:27.0919] <DFU Device 01F3B8D8>: operation 0 progress 50 [15:58:27.0950] <DFU Device 01F3B8D8>: operation 0 progress 51 [15:58:27.0965] <DFU Device 01F3B8D8>: operation 0 progress 52 [15:58:27.0981] <DFU Device 01F3B8D8>: operation 0 progress 53 [15:58:28.0012] <DFU Device 01F3B8D8>: operation 0 progress 54 [15:58:28.0028] <DFU Device 01F3B8D8>: operation 0 progress 55 [15:58:28.0059] <DFU Device 01F3B8D8>: operation 0 progress 56 [15:58:28.0075] <DFU Device 01F3B8D8>: operation 0 progress 57 [15:58:28.0090] <DFU Device 01F3B8D8>: operation 0 progress 58 [15:58:28.0121] <DFU Device 01F3B8D8>: operation 0 progress 59 [15:58:28.0137] <DFU Device 01F3B8D8>: operation 0 progress 60 [15:58:28.0153] <DFU Device 01F3B8D8>: operation 0 progress 61 [15:58:28.0184] <DFU Device 01F3B8D8>: operation 0 progress 62 [15:58:28.0199] <DFU Device 01F3B8D8>: operation 0 progress 63 [15:58:28.0231] <DFU Device 01F3B8D8>: operation 0 progress 64 [15:58:28.0246] <DFU Device 01F3B8D8>: operation 0 progress 65 [15:58:28.0262] <DFU Device 01F3B8D8>: operation 0 progress 66 [15:58:28.0293] <DFU Device 01F3B8D8>: operation 0 progress 67 [15:58:28.0309] <DFU Device 01F3B8D8>: operation 0 progress 68 [15:58:28.0324] <DFU Device 01F3B8D8>: operation 0 progress 69 [15:58:28.0355] <DFU Device 01F3B8D8>: operation 0 progress 70 [15:58:28.0371] <DFU Device 01F3B8D8>: operation 0 progress 71 [15:58:28.0402] <DFU Device 01F3B8D8>: operation 0 progress 72 [15:58:28.0418] <DFU Device 01F3B8D8>: operation 0 progress 73 [15:58:28.0433] <DFU Device 01F3B8D8>: operation 0 progress 74 [15:58:28.0465] <DFU Device 01F3B8D8>: operation 0 progress 75 [15:58:28.0480] <DFU Device 01F3B8D8>: operation 0 progress 76 [15:58:28.0496] <DFU Device 01F3B8D8>: operation 0 progress 77 [15:58:28.0527] <DFU Device 01F3B8D8>: operation 0 progress 78 [15:58:28.0543] <DFU Device 01F3B8D8>: operation 0 progress 79 [15:58:28.0574] <DFU Device 01F3B8D8>: operation 0 progress 80 [15:58:28.0589] <DFU Device 01F3B8D8>: operation 0 progress 81 [15:58:28.0605] <DFU Device 01F3B8D8>: operation 0 progress 82 [15:58:28.0636] <DFU Device 01F3B8D8>: operation 0 progress 83 [15:58:28.0652] <DFU Device 01F3B8D8>: operation 0 progress 84 [15:58:28.0667] <DFU Device 01F3B8D8>: operation 0 progress 85 [15:58:28.0699] <DFU Device 01F3B8D8>: operation 0 progress 86 [15:58:28.0714] <DFU Device 01F3B8D8>: operation 0 progress 87 [15:58:28.0745] <DFU Device 01F3B8D8>: operation 0 progress 88 [15:58:28.0761] <DFU Device 01F3B8D8>: operation 0 progress 89 [15:58:28.0777] <DFU Device 01F3B8D8>: operation 0 progress 90 [15:58:28.0808] <DFU Device 01F3B8D8>: operation 0 progress 91 [15:58:28.0823] <DFU Device 01F3B8D8>: operation 0 progress 92 [15:58:28.0839] <DFU Device 01F3B8D8>: operation 0 progress 93 [15:58:28.0870] <DFU Device 01F3B8D8>: operation 0 progress 94 [15:58:28.0886] <DFU Device 01F3B8D8>: operation 0 progress 95 [15:58:28.0917] <DFU Device 01F3B8D8>: operation 0 progress 96 [15:58:28.0933] <DFU Device 01F3B8D8>: operation 0 progress 97 [15:58:28.0948] <DFU Device 01F3B8D8>: operation 0 progress 98 [15:58:28.0979] <DFU Device 01F3B8D8>: operation 0 progress 99 [15:58:28.0979] WinDFU::UploadData: EOF, cbRead: 1116 [15:58:28.0995] <DFU Device 01F3B8D8>: operation 0 progress 100 [15:58:28.0995] WinDFU::UploadData: ZLP [15:58:29.0011] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [15:58:29.0011] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [15:58:29.0011] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [15:58:29.0011] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [15:58:32.0021] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [15:58:32.0021] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [15:58:32.0021] WinDFU::ResetDevice: resetting... [15:58:32.0099] WinDFU::FinalizeDfuUpdate: success [15:58:32.0099] <DFU Device 01F3B8D8>: DFU succeeded [15:58:32.0099] Finished DFU Restore Phase: Successful [15:58:32.0318] DFU mode device disconnected [15:58:32.0318] Device removed when in state Restoring, moving device to transition state [15:58:32.0318] Changing state from 'Restoring' to 'Transitioning' [15:58:32.0318] Creating timer to monitor transition [15:58:34.0347] Recovery mode device connected [15:58:34.0347] Transitioning device returned, continuing restore. [15:58:34.0347] Canceling timer [15:58:34.0347] Changing state from 'Transitioning' to 'Restoring' [15:58:34.0347] requested restore behavior: Erase [15:58:34.0362] requested variant: Erase [15:58:34.0362] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "iBSS" has been previously personalized; skipping it [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "LLB" has been previously personalized; skipping it [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: nothing to be done [15:58:35.0173] iBoot build-version = iBoot-1940.10.58 [15:58:35.0173] iBoot build-style = RELEASE [15:58:35.0173] requested restore behavior: Erase [15:58:35.0173] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0173] requested restore behavior: Erase [15:58:35.0173] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0173] unable to open device_map.txt: No such file or directory [15:58:35.0173] found device map entry for 0x00008940 0x00000008. boardConfig=n94ap platform=s5l8940x [15:58:35.0173] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options [15:58:35.0173] AMDeviceIoControl: GetOverlappedResult failed [15:58:35.0173] AMDeviceIoControl: pipe stall [15:58:35.0189] USBControlTransfer: error 31, usbd status c0000004 [15:58:35.0189] command device request for 'getenv radio-error' failed: 2008 [15:58:35.0189] radio-error not set [15:58:35.0189] unable to open device_map.txt: No such file or directory [15:58:35.0189] <Recovery Mode Device 06A552D8>: production fused device [15:58:35.0189] requested restore behavior: Erase [15:58:35.0189] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0189] requested restore behavior: Erase [15:58:35.0189] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0189] interface has 1 endpoints, file pipe = 1 [15:58:35.0189] [15:58:35.0189] <Recovery Mode Device 06A552D8>: operation 4 progress -1 [15:58:35.0189] unable to open device_map.txt: No such file or directory [15:58:35.0189] found device map entry for 0x00008940 0x00000008. boardConfig=n94ap platform=s5l8940x [15:58:35.0189] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options [15:58:35.0189] requested restore behavior: Erase [15:58:35.0189] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0189] requested restore behavior: Erase [15:58:35.0205] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0205] <Recovery Mode Device 06A552D8>: operation 42 progress -1 [15:58:35.0205] requested restore behavior: Erase [15:58:35.0205] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:36.0234] <Recovery Mode Device 06A552D8>: operation 5 progress -1 [15:58:36.0593] unable to open device_map.txt: No such file or directory [15:58:36.0593] found device map entry for 0x00008940 0x00000008. boardConfig=n94ap platform=s5l8940x [15:58:36.0593] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options [15:58:36.0593] AMDeviceIoControl: GetOverlappedResult failed [15:58:36.0593] AMDeviceIoControl: pipe stall [15:58:36.0593] USBControlTransfer: error 31, usbd status c0000004 [15:58:36.0593] command device request for 'getenv ramdisk-delay' failed: 2008 [15:58:38.0278] <Recovery Mode Device 06A552D8>: operation 6 progress -1 [15:58:39.0292] <Recovery Mode Device 06A552D8>: operation 7 progress -1 [15:58:39.0619] <Recovery Mode Device 06A552D8>: operation 8 progress -1 [15:58:39.0619] unable to open device_map.txt: No such file or directory [15:58:39.0619] found device map entry for 0x00008940 0x00000008. boardConfig=n94ap platform=s5l8940x [15:58:39.0619] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options [15:58:39.0619] <Recovery Mode Device 06A552D8>: operation 9 progress -1 [15:58:39.0619] <Recovery Mode Device 06A552D8>: Recovery mode succeeded [15:58:39.0619] Finished Recovery Restore Phase: Successful [15:58:41.0554] Recovery mode device disconnected [15:58:41.0554] Device removed when in state Restoring, moving device to transition state [15:58:41.0554] Changing state from 'Restoring' to 'Transitioning' [15:58:41.0554] Creating timer to monitor transition [15:58:45.0427] RestoreOS mode device connected [15:58:45.0427] Transitioning device returned, continuing restore. [15:58:45.0427] Canceling timer [15:58:45.0427] Changing state from 'Transitioning' to 'Restoring' [15:58:45.0427] <Restore Device 0CB7D1C8>: operation 44 progress -1 [15:58:45.0427] requested restore behavior: Erase [15:58:45.0427] requested variant: Erase [15:58:45.0427] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:46.0241] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False [15:58:46.0241] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" [15:58:46.0241] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "iBSS" has been previously personalized; skipping it [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "LLB" has been previously personalized; skipping it [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: nothing to be done [15:58:46.0256] requested restore behavior: Erase [15:58:46.0256] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:46.0272] device did not return saved USB log [15:58:46.0272] device did not return saved panic log [15:58:46.0272] connected to service com.apple.mobile.restored [15:58:46.0272] using protocol version 13 [15:58:46.0272] unable to open device_map.txt: No such file or directory [15:58:46.0272] board config = n94ap [15:58:46.0272] no value returned for BootArgs [15:58:46.0272] _copyDeviceProperty() failed for restore bootargs [15:58:46.0272] no value returned for MarketingPartNumber [15:58:46.0272] _copyDeviceProperty() failed for mpn [15:58:46.0272] requested restore behavior: Erase [15:58:46.0272] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:46.0287] value query for 'HardwareModel' returned 'N94AP' [15:58:46.0287] <Restore Device 0CB7D1C8>: operation 28 progress -1 [15:59:58.0016] RestoreOS mode device disconnected [15:59:58.0016] Device removed when in state Restoring, moving device to transition state [15:59:58.0016] Changing state from 'Restoring' to 'Transitioning' [15:59:58.0016] Creating timer to monitor transition [15:59:58.0016] recv(4824, 4) failed: connection closed [15:59:58.0016] unable to read message size: -1 [15:59:58.0016] unable to read message from device [15:59:58.0016] AMRAuthInstallDeletePersonalizedBundle [15:59:58.0391] Restore completed, status:9 [15:59:58.0391] Failure Description: [15:59:58.0391] Depth:0 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 9 [15:59:58.0391] Depth:1 Error:The operation couldn\U2019t be completed. (AMRestoreErrorDomain error 9 - Failed to receive message from device) 2014-07-06 23:15:57.230 [3552:1490]: restore library built Feb 12 2014 at 16:27:17 2014-07-06 23:15:57.230 [3552:1490]: iTunes: iTunes 11.2.2.3 2014-07-06 23:15:57.230 [3552:1490]: iTunes: Software payload version: 11D257 2014-07-06 23:15:57.230 [3552:1490]: iTunes: Using MobileRestore state machine [21:17:51.0516] Changing state from 'Idle' to 'Restoring' [21:17:51.0516] device software does not support nonce generation [21:17:51.0516] requested restore behavior: Erase [21:17:51.0516] requested variant: Erase [21:17:51.0516] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 0696FC10 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 0696FD30 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode" [21:17:52.0327] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 065E2288 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>} [21:17:52.0327] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled. [21:17:52.0327] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per141D.tmp/amai/debug/tss-request.plist [21:17:52.0686] amai: tss_submit_job: HttpQueryInfo returned 200 [21:17:52.0858] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) [21:17:52.0858] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per141D.tmp/amai/debug/tss-response.plist [21:17:52.0920] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" [21:17:52.0936] <DFU Device 05A845D8>: production fused device [21:17:52.0936] requested restore behavior: Erase [21:17:52.0936] device software does not support nonce generation [21:17:52.0936] WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ab93d329 [21:17:52.0936] WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ab93d329 [21:17:52.0967] <DFU Device 05A845D8>: operation 0 progress 2 [21:17:52.0982] <DFU Device 05A845D8>: operation 0 progress 5 [21:17:52.0998] <DFU Device 05A845D8>: operation 0 progress 8 [21:17:53.0014] <DFU Device 05A845D8>: operation 0 progress 10 [21:17:53.0029] <DFU Device 05A845D8>: operation 0 progress 13 [21:17:53.0045] <DFU Device 05A845D8>: operation 0 progress 16 [21:17:53.0060] <DFU Device 05A845D8>: operation 0 progress 18 [21:17:53.0076] <DFU Device 05A845D8>: operation 0 progress 21 [21:17:53.0092] <DFU Device 05A845D8>: operation 0 progress 24 [21:17:53.0107] <DFU Device 05A845D8>: operation 0 progress 26 [21:17:53.0123] <DFU Device 05A845D8>: operation 0 progress 29 [21:17:53.0138] <DFU Device 05A845D8>: operation 0 progress 32 [21:17:53.0154] <DFU Device 05A845D8>: operation 0 progress 34 [21:17:53.0170] <DFU Device 05A845D8>: operation 0 progress 37 [21:17:53.0185] <DFU Device 05A845D8>: operation 0 progress 40 [21:17:53.0201] <DFU Device 05A845D8>: operation 0 progress 42 [21:17:53.0216] <DFU Device 05A845D8>: operation 0 progress 45 [21:17:53.0232] <DFU Device 05A845D8>: operation 0 progress 48 [21:17:53.0248] <DFU Device 05A845D8>: operation 0 progress 50 [21:17:53.0263] <DFU Device 05A845D8>: operation 0 progress 53 [21:17:53.0279] <DFU Device 05A845D8>: operation 0 progress 56 [21:17:53.0294] <DFU Device 05A845D8>: operation 0 progress 59 [21:17:53.0310] <DFU Device 05A845D8>: operation 0 progress 61 [21:17:53.0326] <DFU Device 05A845D8>: operation 0 progress 64 [21:17:53.0341] <DFU Device 05A845D8>: operation 0 progress 67 [21:17:53.0357] <DFU Device 05A845D8>: operation 0 progress 69 [21:17:53.0372] <DFU Device 05A845D8>: operation 0 progress 72 [21:17:53.0388] <DFU Device 05A845D8>: operation 0 progress 75 [21:17:53.0404] <DFU Device 05A845D8>: operation 0 progress 77 [21:17:53.0419] <DFU Device 05A845D8>: operation 0 progress 80 [21:17:53.0435] <DFU Device 05A845D8>: operation 0 progress 83 [21:17:53.0450] <DFU Device 05A845D8>: operation 0 progress 85 [21:17:53.0466] <DFU Device 05A845D8>: operation 0 progress 88 [21:17:53.0482] <DFU Device 05A845D8>: operation 0 progress 91 [21:17:53.0497] <DFU Device 05A845D8>: operation 0 progress 93 [21:17:53.0513] <DFU Device 05A845D8>: operation 0 progress 96 [21:17:53.0528] <DFU Device 05A845D8>: operation 0 progress 99 [21:17:53.0528] WinDFU::UploadData: EOF, cbRead: 554 [21:17:53.0544] <DFU Device 05A845D8>: operation 0 progress 100 [21:17:53.0544] WinDFU::UploadData: ZLP [21:17:53.0560] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [21:17:53.0560] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [21:17:53.0560] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [21:17:53.0560] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [21:17:56.0570] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [21:17:56.0570] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [21:17:56.0570] WinDFU::ResetDevice: resetting... [21:17:56.0648] WinDFU::FinalizeDfuUpdate: success [21:17:56.0648] <DFU Device 05A845D8>: DFU succeeded [21:17:56.0648] Finished DFU Restore Phase: Successful [21:17:56.0836] DFU mode device disconnected [21:17:56.0836] Device removed when in state Restoring, moving device to transition state [21:17:56.0836] Changing state from 'Restoring' to 'Transitioning' [21:17:56.0836] Creating timer to monitor transition [21:17:57.0938] DFU mode device connected [21:17:57.0939] Transitioning device returned, continuing restore. [21:17:57.0940] Canceling timer [21:17:57.0940] Changing state from 'Transitioning' to 'Restoring' [21:17:57.0941] AppleDevice::GetDeviceID: failed for iBoot [21:17:57.0942] requested restore behavior: Erase [21:17:57.0943] requested variant: Erase [21:17:57.0943] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [21:17:58.0748] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is True [21:17:58.0748] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreLogo" Digest = "<CFData 05B6CAA8 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0748] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDeviceTree" Digest = "<CFData 05B6CB38 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreKernelCache" Digest = "<CFData 05B6CBC8 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreRamDisk" Digest = "<CFData 05B6CB80 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 05B6CD30 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 05B6CD78 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "KernelCache" Digest = "<CFData 05B6CDC0 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow1" Digest = "<CFData 05B6CE08 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow0" Digest = "<CFData 0696FB38 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 0696FB80 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBoot" Digest = "<CFData 0696FBC8 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DeviceTree" Digest = "<CFData 0696FC10 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging1" Digest = "<CFData 0696FC58 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AppleLogo" Digest = "<CFData 0696FCA0 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryPlugin" Digest = "<CFData 0696FCE8 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryFull" Digest = "<CFData 0696FD30 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging0" Digest = "<CFData 0696FD78 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0780] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RecoveryMode" Digest = "<CFData 0696FDC0 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0780] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 065E5140 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>} [21:17:58.0780] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled. [21:17:58.0780] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per141D.tmp/amai/debug/tss-request.plist [21:17:58.0982] amai: tss_submit_job: HttpQueryInfo returned 200 [21:17:59.0154] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) [21:17:59.0170] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per141D.tmp/amai/debug/tss-response.plist [21:17:59.0170] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "iBSS" has been previously personalized; skipping it [21:17:59.0170] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "LLB" has been previously personalized; skipping it [21:17:59.0185] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" [21:17:59.0201] <DFU Device 0BFE9138>: production fused device [21:17:59.0201] requested restore behavior: Erase [21:17:59.0201] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [21:17:59.0201] AppleDevice::GetDeviceID: failed for iBoot [21:17:59.0201] WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ce671dc7 [21:17:59.0201] WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ce671dc7 [21:17:59.0232] <DFU Device 0BFE9138>: operation 0 progress 0 [21:17:59.0248] <DFU Device 0BFE9138>: operation 0 progress 1 [21:17:59.0263] <DFU Device 0BFE9138>: operation 0 progress 2 [21:17:59.0294] <DFU Device 0BFE9138>: operation 0 progress 3 [21:17:59.0310] <DFU Device 0BFE9138>: operation 0 progress 4 [21:17:59.0326] <DFU Device 0BFE9138>: operation 0 progress 5 [21:17:59.0357] <DFU Device 0BFE9138>: operation 0 progress 6 [21:17:59.0372] <DFU Device 0BFE9138>: operation 0 progress 7 [21:17:59.0404] <DFU Device 0BFE9138>: operation 0 progress 8 [21:17:59.0419] <DFU Device 0BFE9138>: operation 0 progress 9 [21:17:59.0435] <DFU Device 0BFE9138>: operation 0 progress 10 [21:17:59.0466] <DFU Device 0BFE9138>: operation 0 progress 11 [21:17:59.0482] <DFU Device 0BFE9138>: operation 0 progress 12 [21:17:59.0497] <DFU Device 0BFE9138>: operation 0 progress 13 [21:17:59.0528] <DFU Device 0BFE9138>: operation 0 progress 14 [21:17:59.0544] <DFU Device 0BFE9138>: operation 0 progress 15 [21:17:59.0575] <DFU Device 0BFE9138>: operation 0 progress 16 [21:17:59.0591] <DFU Device 0BFE9138>: operation 0 progress 17 [21:17:59.0606] <DFU Device 0BFE9138>: operation 0 progress 18 [21:17:59.0638] <DFU Device 0BFE9138>: operation 0 progress 19 [21:17:59.0653] <DFU Device 0BFE9138>: operation 0 progress 20 [21:17:59.0669] <DFU Device 0BFE9138>: operation 0 progress 21 [21:17:59.0700] <DFU Device 0BFE9138>: operation 0 progress 22 [21:17:59.0716] <DFU Device 0BFE9138>: operation 0 progress 23 [21:17:59.0747] <DFU Device 0BFE9138>: operation 0 progress 24 [21:17:59.0762] <DFU Device 0BFE9138>: operation 0 progress 25 [21:17:59.0778] <DFU Device 0BFE9138>: operation 0 progress 26 [21:17:59.0809] <DFU Device 0BFE9138>: operation 0 progress 27 [21:17:59.0825] <DFU Device 0BFE9138>: operation 0 progress 28 [21:17:59.0840] <DFU Device 0BFE9138>: operation 0 progress 29 [21:17:59.0872] <DFU Device 0BFE9138>: operation 0 progress 30 [21:17:59.0887] <DFU Device 0BFE9138>: operation 0 progress 31 [21:17:59.0918] <DFU Device 0BFE9138>: operation 0 progress 32 [21:17:59.0934] <DFU Device 0BFE9138>: operation 0 progress 33 [21:17:59.0950] <DFU Device 0BFE9138>: operation 0 progress 34 [21:17:59.0981] <DFU Device 0BFE9138>: operation 0 progress 35 [21:17:59.0996] <DFU Device 0BFE9138>: operation 0 progress 36 [21:18:00.0012] <DFU Device 0BFE9138>: operation 0 progress 37 [21:18:00.0043] <DFU Device 0BFE9138>: operation 0 progress 38 [21:18:00.0059] <DFU Device 0BFE9138>: operation 0 progress 39 [21:18:00.0090] <DFU Device 0BFE9138>: operation 0 progress 40 [21:18:00.0106] <DFU Device 0BFE9138>: operation 0 progress 41 [21:18:00.0121] <DFU Device 0BFE9138>: operation 0 progress 42 [21:18:00.0152] <DFU Device 0BFE9138>: operation 0 progress 43 [21:18:00.0168] <DFU Device 0BFE9138>: operation 0 progress 44 [21:18:00.0184] <DFU Device 0BFE9138>: operation 0 progress 45 [21:18:00.0215] <DFU Device 0BFE9138>: operation 0 progress 46 [21:18:00.0230] <DFU Device 0BFE9138>: operation 0 progress 47 [21:18:00.0262] <DFU Device 0BFE9138>: operation 0 progress 48 [21:18:00.0277] <DFU Device 0BFE9138>: operation 0 progress 49 [21:18:00.0293] <DFU Device 0BFE9138>: operation 0 progress 50 [21:18:00.0324] <DFU Device 0BFE9138>: operation 0 progress 51 [21:18:00.0340] <DFU Device 0BFE9138>: operation 0 progress 52 [21:18:00.0355] <DFU Device 0BFE9138>: operation 0 progress 53 [21:18:00.0386] <DFU Device 0BFE9138>: operation 0 progress 54 [21:18:00.0402] <DFU Device 0BFE9138>: operation 0 progress 55 [21:18:00.0433] <DFU Device 0BFE9138>: operation 0 progress 56 [21:18:00.0449] <DFU Device 0BFE9138>: operation 0 progress 57 [21:18:00.0464] <DFU Device 0BFE9138>: operation 0 progress 58 [21:18:00.0496] <DFU Device 0BFE9138>: operation 0 progress 59 [21:18:00.0511] <DFU Device 0BFE9138>: operation 0 progress 60 [21:18:00.0527] <DFU Device 0BFE9138>: operation 0 progress 61 [21:18:00.0558] <DFU Device 0BFE9138>: operation 0 progress 62 [21:18:00.0574] <DFU Device 0BFE9138>: operation 0 progress 63 [21:18:00.0605] <DFU Device 0BFE9138>: operation 0 progress 64 [21:18:00.0620] <DFU Device 0BFE9138>: operation 0 progress 65 [21:18:00.0636] <DFU Device 0BFE9138>: operation 0 progress 66 [21:18:00.0667] <DFU Device 0BFE9138>: operation 0 progress 67 [21:18:00.0683] <DFU Device 0BFE9138>: operation 0 progress 68 [21:18:00.0698] <DFU Device 0BFE9138>: operation 0 progress 69 [21:18:00.0730] <DFU Device 0BFE9138>: operation 0 progress 70 [21:18:00.0745] <DFU Device 0BFE9138>: operation 0 progress 71 [21:18:00.0776] <DFU Device 0BFE9138>: operation 0 progress 72 [21:18:00.0792] <DFU Device 0BFE9138>: operation 0 progress 73 [21:18:00.0808] <DFU Device 0BFE9138>: operation 0 progress 74 [21:18:00.0839] <DFU Device 0BFE9138>: operation 0 progress 75 [21:18:00.0854] <DFU Device 0BFE9138>: operation 0 progress 76 [21:18:00.0870] <DFU Device 0BFE9138>: operation 0 progress 77 [21:18:00.0901] <DFU Device 0BFE9138>: operation 0 progress 78 [21:18:00.0917] <DFU Device 0BFE9138>: operation 0 progress 79 [21:18:00.0948] <DFU Device 0BFE9138>: operation 0 progress 80 [21:18:00.0964] <DFU Device 0BFE9138>: operation 0 progress 81 [21:18:00.0979] <DFU Device 0BFE9138>: operation 0 progress 82 [21:18:01.0010] <DFU Device 0BFE9138>: operation 0 progress 83 [21:18:01.0026] <DFU Device 0BFE9138>: operation 0 progress 84 [21:18:01.0042] <DFU Device 0BFE9138>: operation 0 progress 85 [21:18:01.0073] <DFU Device 0BFE9138>: operation 0 progress 86 [21:18:01.0088] <DFU Device 0BFE9138>: operation 0 progress 87 [21:18:01.0120] <DFU Device 0BFE9138>: operation 0 progress 88 [21:18:01.0135] <DFU Device 0BFE9138>: operation 0 progress 89 [21:18:01.0151] <DFU Device 0BFE9138>: operation 0 progress 90 [21:18:01.0182] <DFU Device 0BFE9138>: operation 0 progress 91 [21:18:01.0198] <DFU Device 0BFE9138>: operation 0 progress 92 [21:18:01.0213] <DFU Device 0BFE9138>: operation 0 progress 93 [21:18:01.0244] <DFU Device 0BFE9138>: operation 0 progress 94 [21:18:01.0260] <DFU Device 0BFE9138>: operation 0 progress 95 [21:18:01.0291] <DFU Device 0BFE9138>: operation 0 progress 96 [21:18:01.0307] <DFU Device 0BFE9138>: operation 0 progress 97 [21:18:01.0322] <DFU Device 0BFE9138>: operation 0 progress 98 [21:18:01.0354] <DFU Device 0BFE9138>: operation 0 progress 99 [21:18:01.0354] WinDFU::UploadData: EOF, cbRead: 1116 [21:18:01.0369] <DFU Device 0BFE9138>: operation 0 progress 100 [21:18:01.0369] WinDFU::UploadData: ZLP [21:18:01.0385] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [21:18:01.0385] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [21:18:01.0385] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [21:18:01.0385] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [21:18:04.0396] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [21:18:04.0396] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [21:18:04.0396] WinDFU::ResetDevice: resetting... [21:18:04.0474] WinDFU::FinalizeDfuUpdate: success [21:18:04.0474] <DFU Device 0BFE9138>: DFU succeeded [21:18:04.0474] Finished DFU Restore Phase: Successful [21:18:04.0676] DFU mode device disconnected [21:18:04.0692] Device removed when in state Restoring, moving device to transition state [21:18:04.0692] Changing state from 'Restoring' to 'Transitioning' [21:18:04.0692] Creating timer to monitor transition [21:18:08.0230] Restore completed, status:4014 [21:18:08.0230] Failure Description: [21:18:08.0230] Depth:0 Error:Unexpected device state 'DFU' expected 'Recovery' |
I have exactly the same problem with an iPhone 5. Restore freezes on the Apple logo with an empty progress bar. The log hangs at same line as you: <Restore Device xxxxxxx>: operation 28 progress -1 And only way to move away is to disconnect the device (and fail the restore). Did you have any info after your post by any chance? |
