GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   iPhone, iPad, iPod Hardware Repair (https://forum.gsmhosting.com/vbb/f631/)
-   -   iPhone 4s keep searching only solution (https://forum.gsmhosting.com/vbb/f631/iphone-4s-keep-searching-only-solution-1619850/)
boknoy 02-25-2013 12:00
unit = iphone 4s 64gb lock to smart pp
problem= keep searching
action taken= try another smart sim = no luck
retore to ios 6.1.2
activate
set time manualy
restart
no luck
i open the phone check all posible line open like antina fuse and soso....blah all is good
re asimble then power on reset network, manualy set the time.
restart again mmmnnn no luck
any solution plss????
http://i1237.photobucket.com/albums/...psa832934a.png
GULAB-GUL 02-25-2013 12:23
try to jailbreak it and install ultrasn0w
boknoy 02-26-2013 07:44
done by this
open again the phone and check all hide parts near to the signal components and i discover this.
http://i1237.photobucket.com/albums/...psa3ac4b6e.jpg
imediatly get another board and look the missing parts.
http://i1237.photobucket.com/albums/...ps6558ee7f.jpg
since not easy to replace this parts by using hot air. i try to jumper and it works
http://i1237.photobucket.com/albums/...ps149e83f1.jpg
http://i1237.photobucket.com/albums/...ps2d36d457.png
http://i1237.photobucket.com/albums/...psd2711abb.png
vow!
inkanet 03-29-2013 18:39
hi how u jumper it? not more photos ?
tarek hamd 06-04-2013 08:40
i have iphone 4s give error -1
any solve
plzzzzzzzz
boknoy 06-06-2013 03:26
any solve
plzzzzzzzz
baseband chip is the damage.
try reball or change
not all do this will be done.
just depend upon your hand carry the gadget that you use.
tristan1990 06-13-2013 21:10
How did you actually do the jumper? What do I need to do it? And how do I do it.
Thanks
boknoy 09-29-2013 10:09
Thanks
since not long to jumper, just jumper by lead only use sharp soldering iron. the missing parts is small resistor only
Migs7 09-30-2013 10:09
Will this work on any resistor?
gustavogomesbr 09-30-2013 22:33
I have a similar problem.
Missing FL9_RF, C107_RF and C59_RF.
Tried to jump with no sucess, any other possibilites?
Still just searching.
Migs7 09-30-2013 22:57
Im sure somebody will chime in.
Is the phone u speak of gsm or cdma?
gustavogomesbr 10-01-2013 01:49
Its a GSM iPhone 4S
I saw the schematics for this components an instead of jump the pads I grounded the components before them on the chain
gustavogomesbr 10-01-2013 19:28
Someone with a different suggestion?
Feerer 11-19-2013 11:23
Thanks boknoy for that thread, it really helped!
Got iphone 4S with same problem, though my mainboard wasn't that messed up.
My problem was that FL2_RF was loose and was pushed against C79_RF, so I managed to fix it and got signal.
Unfortunately it lasted only 2 weeks and then again "Searching" and "No Signal" appeared. So I took it apart again but everything seemed fine, no short circuits or missing grounds. So I put it together again and finally managed to contact emergency service, with that, phone had signal again. That one lasted for 2 days, then again no signal.
Both times this happened was while phone was charging, don't know if these thing are tied or just luck.
Did I missed something? I have run out of ideas what may cause this?
I really would appreciate some help.
I would also attach image of details what i soldered, but I can't post links or attach image..
marhabamobiles 08-21-2014 06:54
Originally Posted by boknoy (Post 9224183)
done by this
vow!
Thanks A Lot My Problem has solved
Page generated in 0.14982 seconds with 6 queries
