04-26-2013, 05:12 | #33 (permalink) |
Registered User Join Date: Jul 2004 Location: nonthaburi thailand Age: 51
Member: 73464 Status: Offline Thanks Meter: 26 | thankyou i need to be sure becouse i have to removed it by solder make it crack not use hot air thankyou next step find that ic form ebay or aliexpress |
05-27-2013, 10:18 | #43 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1921016 Status: Offline Thanks Meter: 3 | please update. i have 2 phones like this Levani_Pmic how did you fix the problem?this ic is extremely near the cpu if i will use hot gun the cpu will be dead! Last edited by tomerzhr245; 05-27-2013 at 10:27. |
05-27-2013, 10:37 | #44 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Lima, Peru.Lat/Lon:, 12.0° S 7
Member: 184182 Status: Offline Sonork: 100.1622565 Thanks Meter: 97 | I didnt experiment with the hardware side of things but when an iphone 5 i had went below 2% charging it would not turn on. Normal charger would also not work for that matter. After a while I plugged it in to an Ipad Charger 2.1Amps and charged for half an hour. It instantly turned on and then was charging on the normal iphone charger. Now if you have any UN-fried or electrically damaged iphones (other than surged ones) then try and post the result. And do not charge on ipad charger for longer as it heats up the battery and discharges quicker. |
05-27-2013, 11:03 | #45 (permalink) |
No Life Poster Join Date: Oct 2011 Location: tbilisi, georgia Age: 33
Member: 1679251 Status: Offline Thanks Meter: 385 | you must use cover for protect CPU from heating, also you need big caution for not damaged prints under that IC. it's not easy to do this. |
The Following User Says Thank You to Levani_Pmic For This Useful Post: |
