iPhone 5 Battery Drain Problem, U2 IC Problem? Hello Guys, I bought iPhone 5 few days back and I observed very less battery time roughly around 8 hours on standby. I restored it using iTunes as a new phone the battery time ramained the same 8 to 9 hours without use even without wifi and SIM. Thought it would be a battery problem then I replaced it with another one, the problem remains the same 8-9 hours battery stand by time. In short, tried all software solution and changing the battery problem, is it related to U2 IC? My phone charging is working fine just the battery time problem. The phone died once it was drained out then had to take the battery out charge it manually then worked. |
i have the same problem exactly. any solution?? thanks!! |
repalce u2 ic bro... |
I think that is a problem on some verisons iPhone 5 battery drain. I have many experience on many pieces iPhone 5. BR |
Just replace the u2 ic and it works perfectly |
yep, try replace U2 IC. |
