Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-02-2015, 17:22   #1 (permalink)
Member: 1784782
vertical lines iphone 5
hi, please help, C149 volt -1.8 volt normal is -5v not?
Old 11-02-2015, 22:17   #2 (permalink)
Member: 1208225
Thanks Meter: 13
Try to measure these points
[/IMG]
Old 11-03-2015, 00:41   #3 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Check also C154 and c170 for short.
C170 is often the bad one
The Following User Says Thank You to HDccam For This Useful Post:
Old 11-03-2015, 06:06   #4 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
Is this problem same woth zebra line on iPhone 5
Sent from my iPhone using Tapatalk
Old 11-03-2015, 14:16   #5 (permalink)
Member: 1784782
thanks, solution is remove c170
Old 11-03-2015, 15:16   #6 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
Where is it ?
Old 11-03-2015, 15:27   #7 (permalink)
Member: 1784782
look at the picture above, in the area below right
Old 11-03-2015, 15:31   #8 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
I have remove it but no luck I think the problem is secondary ic touch ( U14 )
Old 11-04-2015, 00:24   #9 (permalink)
Member: 2077335
Thanks Meter: 11
same here, i have around 1v...what i can do?
thanks!
Old 11-04-2015, 17:16   #10 (permalink)
Member: 1784782
Hi, in my case the solution is remove C170
Old 11-06-2015, 18:09   #11 (permalink)
Member: 2077335
Thanks Meter: 11
tried, but always the same...4 vertical lines on left of the screen!
Old 11-07-2015, 19:55   #12 (permalink)
Member: 1156346
Sonork: 100.1606988
Thanks Meter: 38
after remove cap149 still short also remove Dz4 any solution for zebra lines
Old 11-07-2015, 22:06   #13 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
iPhone 5 Zebra lines: check for shortcut: C149 C154 C156 C170
Old 11-08-2015, 23:18   #14 (permalink)
Member: 1208225
Thanks Meter: 13
I´ve added green boxes around those Caps, you are searcing for shorts.
[/IMG]
Page generated in 0.17906 seconds with 8 queries
