iphone 5, error 4013 3 Attachment(s) Hello, I have iphone 5 when try to restore get error 4013, and the error lines on iphone lcd, (take a look) by the way, i rty to change 1 cable 2 new battery 3 new charger / usb flat cable Attachment 328151 Attachment 328152 Attachment 328153 |
Which version ios do u use, and make sure 3 things 1. restart ur pc 2.try diff usb port Note: few days back i receive same issue yesterday only its solved ios 7.04 to 7.1.2 |
thanks for your replay,, i try 3 diffirent pc, and 2 good usb cable. i do not know what was the ver, because this is for my customer :confused::confused: |
Put the phone in DFU mode and shutdown and completely turn off ur internet connection after 1 min restart it > pc, dont start any programme , click on itunes > and locate the ios and complete it, few mins back i have done> its works |
i try what you said... not success. :mad::mad::mad: |
Disconnect front camera flex, try sw update like that. |
2sharbel, may be u2 problem? |
Hi, I think it's the compass ic U16, i had the same problem, after desolder U16 everything was OK!!;) Good Luck |
Replace front camera flex. |
I replaced front camera flex and It's solved the problem! |
It's a normal problem. ;) |
How?..."................................ |
4013 fixed, 100% solution Quote:
U16 SCHEMATIC |
Bro just put jumper on c133 to c303 |
+1 for U16 solution. If removing front camera flex does not fix this issue, try removing U16 IC (near front camera flex/screwhole) and phone should restore properly. Thanks for this solution! |
