02-04-2014, 23:26 | #76 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | i have an iphone 5 water damaged. I have repaired everything and it is now completely working,but it make noise (white noise) from the mic. It does make this noise even if i disconnect the microphone module from the motherboard. There is also another problem, it does not detect when i connect the earphone. Someone have an idea where to look ? Thanks |
02-05-2014, 23:55 | #78 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2075221 Status: Offline Thanks Meter: 0 | Hello bro, i have 5 water damage, all sort has clear, iphone now turn on normaly, signal some time goes to no service and wifi grey out, how do i fix it?? Sent from my iPhone using Tapatalk |
02-06-2014, 13:35 | #79 (permalink) |
Member: 1873863 Status: Offline Thanks Meter: 67 | Hi ansari, yes i have changed the dock flex + microphone, but the problem persist even without connecting the flex to the board. I have tried also to remove the mic2 (connected to the power button flex), same result. It should be something on the board, because even the headphone is not detected (if i connect headphone, i still ear sound from the internal speaker) |
02-12-2014, 12:12 | #81 (permalink) |
Insane Poster Join Date: Feb 2014
Member: 2126761 Status: Offline Thanks Meter: 4 | Iphone 5 no signal Hi guys, after replacing screen and LCD have no signal at all, I didn't took apart anything but display. I try to find a blue coil like iphone 4 but didn't found it, Can anyone help plzz? |
02-12-2014, 12:46 | #83 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 331337 Status: Offline Thanks Meter: 72 | Have an iPhone 5 and have fitted 2 new docks and they will not charge, I installed the old one and still the same. i have another iphone 5 so i took battery out and tried with that battery phone comes on but when i connect to charger its not charging. charger is working on other phone so nothing wrong with charger but something wrong in the phone. pleasse help me with solution. thnx in advance |
02-12-2014, 13:20 | #84 (permalink) | |
Member: 1873863 Status: Offline Thanks Meter: 67 | Quote:
The phone was dropped, or water damaged ? | |
02-13-2014, 17:58 | #87 (permalink) |
Junior Member Join Date: May 2012
Member: 1754654 Status: Offline Thanks Meter: 0 | Iphone 5 battery Percentage and 2G Problem Hello... I have iphone 5 with water damage..the problem is about charging..It's charging normally..but percentage is not increasing..when i reboot, it show increasing battery percentage..so, i can see the "real" battery percentage when i reboot it.. And second problem ... 2G Network is not working..Just 3G ...When i switch to 2G..it show only "Searching"... Any solution??? Thank you.. |
02-14-2014, 06:06 | #88 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1961995 Status: Offline Thanks Meter: 0 | no wifi I need to see a pic of the wifi antenna or schematic diagram. I am not sure if apart is missing and can place a jumper. Please can someone help with a pic of the wifi antenna Thank you |
