Iphone 5c restarts every 3 or 4 minutes I have an iphone 5c that restarts every 3 or 4 minutes, and the charging percentage never change unless it's restarted. I have swapped battery, swapped screen, swapped lower charging/speaker assembly, and none of that helped. I can get it to run longer if I disable cellular data and restart, but it eventually starts rebooting by itself again. Is this a board level problem? |
Very likely if you have already changed battery. Seems to be a problem with u2 ic. |
Check battery swi line first (usually broken FL11) and then U2 |
You solved your problem yet? |
iphone 5c battery ways ???? plz help |
Hi, I have the same problem any solution for this? Thanks |
checkcbattery, or chec if something goes hot |
