03-20-2017, 18:22 | #1 (permalink) |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | No wifi due to long screw damage? That was fixed now wifi is greyed out says N/A in setting under wifi address. Would this also be caused by long screw? If so which line would it be? |
03-21-2017, 19:05 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | could be you overheated the board when you fixed the screw damage? check for soldering balls around the wifi ic. they pop out from under the ic when too much heat was used. Reball or replace the wifi ic |
03-22-2017, 23:05 | #5 (permalink) | |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | Quote:
Customer said wifi was working before he disassemble the phone. i reballed, changed the wifi ic. it did not work on all three iphone 6. If wifi not work Customer not want to pay. i had to give back. but it would be great if somebody had an idea what does the long screw damage to do with wifi. | |
08-06-2017, 01:53 | #6 (permalink) | |
Junior Member Join Date: Jun 2014
Member: 2197917 Status: Offline Thanks Meter: 0 | Quote:
Hi, Dis you ever find the problem? Same case here. after fixing lsd, no wifi and volume up/down not working. br | |
08-08-2017, 01:14 | #9 (permalink) |
Member: 2197917 Status: Offline Thanks Meter: 0 | yup i can confirm it now. Got the phone fixed, wifi is working. So this one was very badly damaged, and tracks in the third layer on the right side were broken. Had to dig them up to allmost under the shield. thanks all. |
08-08-2017, 01:15 | #10 (permalink) | |
Member: 2598526 Status: Offline Thanks Meter: 52 | Quote:
How many traces are there in the third layer? Do you know what else they're for? Sent from my iPhone using Tapatalk | |
08-08-2017, 05:01 | #11 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
how much heat did you use to damage the pads? I been looking a many youtuve videos where lots of tech are searching why a minimal heat leaves the ip 6 with gray out wifi. | |
