Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-20-2015, 00:52   #1 (permalink)
Member: 1889273
Thanks Meter: 12
all pro techs please help to test IC
hi guys im learning to test ic
i want to know when is good or bad ic
i have multitester
also i donwload Schematics
im testing 5s u2 rf ic
i have 3 questions
1.first picture
i want to know what mean this red lines
http://postimg.org/image/fcxqf8y0x/
2.second picture
where is the volataje of the ic for know if it good or bad
http://postimg.org/image/73dd8d90z/
http://postimg.org/image/tup24dbwf/
3. how i need to put black and red arms of multitester for test ic if is good or bad
or how i need to put in pbc to test + - ground for test voltaje
Old 05-20-2015, 11:41   #2 (permalink)
Member: 2393796
Thanks Meter: 10
1
I think that red line on the corner means the number 1 pin is there
2
all thick lines are power lines
3
use schematics to test the component it connects to like ( c50_rf 0.1UF 6.3v) if its good then it will have correct power voltage to that component from the ic
main power in is where is says IN PP BATT VCC CON
I am sure some one will correct me if I have it wrong.
Old 05-20-2015, 11:46   #3 (permalink)
Member: 2393796
Thanks Meter: 10
sorry 2
is it not 1.0V ?
Old 05-20-2015, 21:35   #4 (permalink)
Member: 1889273
Thanks Meter: 12
Originally Posted by lshoa View Post
sorry 2
is it not 1.0V ?
like this ?
u see the positive and negative ?
is correct for tfest ic and appear 6.3 v mean is good
when is bad nothing appear ?
subir imagenes gratis
Old 05-20-2015, 22:12   #5 (permalink)
Member: 2393796
Thanks Meter: 10
yes is there is a 6.3v there then should be good for that part of ic, but each one needs to be checked for correct output, so 28 ref_byp should be 6.3v and cap should be 0.1uf give or take 20% 0.8uf or 1.2uf would still be good
ref_GND is ground
Bad could be no power or less power than 6.3 or more power than 6.3 or short
so on each leg check to see if correct output input
Old 05-20-2015, 22:54   #6 (permalink)
Member: 1889273
Thanks Meter: 12
ref_GND is ground
thanks friend for the support
im learning
1.for 6.3v value
need to positive red cable in IN and black cable in 28 ref_byp for out and , right?
2.for capacitor 0.1 uf
need to positive red cable in IN, anf for out in ref_GND the black cable ??
Old 05-20-2015, 23:20   #7 (permalink)
Member: 1889273
Thanks Meter: 12
the number 1 pin , what is for ?
Old 05-21-2015, 15:02   #8 (permalink)
Member: 2393796
Thanks Meter: 10
where it has 1 and 2 under it where the red arrow is ?
that is the side of the cap c50_rf 1 = positive and 2 = negative
I am still learning to as there is so much to learn and understand everyone has to ask
Old 05-22-2015, 16:59   #9 (permalink)
Member: 1889273
Thanks Meter: 12
-yeah u are a good teacher
yes for capacito 1 is positive and 2 is negative = 0.1uf
-and for 6.3V
need to positive red cable in IN and black cable in 28 ref_byp for out ?
-numerber 1 pin
View image: u2
is like numeber 1 in cap or is talk about another thing?
Old 05-25-2015, 18:21   #10 (permalink)
Member: 1889273
Thanks Meter: 12
anybody ? can help ??????
Old 05-27-2015, 08:58   #11 (permalink)
Member: 2393796
Thanks Meter: 10
do you get continuity on that path ?
Page generated in 0.18653 seconds with 8 queries
