iPhone 5s Front Camera broken connector !!! Hello guys, i got this iPhone 5s with on-board broken front camera connector, so i have to replace this little connector with a new one, i've already bought it from hong kong, but i've never experienced this sort of repair, i don't want to broke / move anything on the motherboard, can you help me with some suggestion? |
I think it need to replacement new connector only. |
Is there any1 who can help me ? I got all the equipment to do it, kapton and hot air gun, but im not sure about temps, can you suggest me please ? |
buy a cheap flex and first try resolder connector there if you cannot, dont try. before unsolder clean area add flux add some fresh solder. I would use solder iron to remove. But you need be carefull |
U can also use hot air and solder iron together. 270 c low flow. 320 c solder iron. Be carefull not to heat cpu. |
thank you for the tips |
just use a small iron to remove and replace use flux. make the pads flat no points with new solder use flux gel will help keep the connector in position. keep a tiny bit of pressure on the connector once in place with a small screwdriver or pin, solder a couple of legs at the ends to hold it there while you solder the rest. try and keep the connector flat as possible to the board. |
