Iphone 5S Home button ways Hi, Does anyone have the schematics for iphone 5S Home button flex cable to share? I have 1 iphone 5S with a working touch ID but home button click is not working. I tried with a brand new home button flex and obviously the touch ID won't work but home button lick works, so there must be a broken line on the original home button flex which I need the schematics to trace the broken line. Anyone who has the schematics, can you share please? Thanks! |
Right where the click take place open the small round piece and just sratch it with a blade or something pointing.that should fix your problem. Hit thanks bottom Sent from my iPhone 6+ using Tapatalk |
View image: iphone 5s homebutton click ways View image: iphone 5s no mic no homebutton click solution Darkside85 is right. You should first check with the multimeter if the click switch contact it self works. If not.. Open the contact and clean it. Here i made 2 other solutions, when the iphone 5s homebutton touch id works perfectly but the click doesnt. |
I have done that earlier but it doesn't work. Changed the clicker also doesn't help. Ok, I will try the jumper tomorrow, thank you so much! |
Tried the jumper solution on first picture and it works beautifully! Thank you so much! |
Thats Nice to hear:) You press the thanks button in the post if a post is helpful |
FL5 and area around has been checked. Still home button not working. Obviously flexes and buttons replaced. Any more ideas? |
Iphone 5s touch id nort working i have replace new touch revon ... Still don working plz help me |
have same problem. FL5 is ok test new homebutton and new charging flex without success |
I managed to fix a touch id and click flex, it was torn on the start. My jumper ways: https://www.facebook.com/pg/PTRTECH/...79939962490184 (Public no login required) |
