Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-20-2014, 06:47   #1 (permalink)
Member: 2024271
Question Iphone 5S - No Back Light? How easy to fix?
Hey fellas,
I have a iphone 5S that had water damage. There was some corrosion on the board near the lcd connectors, but I cleaned it. The phone seems to operate just fine expect that the back light from the screen will not power up...although if I look close I can still see the icons and the time and everything else on screen. It's just that the screen is very dim since there is no light behind it.
My question is, how easy would this be to fix? Or how much would it cost to fix?
Other Info: I have already switched the LCD screen with a working one and still got the same result. I looked very close to the board and can see one filter missing and some others around it look slightly damaged.
Old 09-20-2014, 20:44   #2 (permalink)
dog68's Avatar
Member: 1728699
Thanks Meter: 212
It depends on how experienced you are, and if you have the tools available. It seems you know a bit, as you refer to a missing filter-which is common, on water damaged iphones, so resoldering the lcd connector, and replacing filters (or jump them) should solve your problem, and if you were to pay to get it repaired, prices could vary from £20 to £40.
Old 09-20-2014, 22:06   #3 (permalink)
Member: 2024271
^Dog68 Oh no, by all means I am not experienced with any type of soldering repairs on water damaged phones. The only reason I said missing filter was because I was looking at one of the 5S back light solution pic's on this forum and they referred to them as filters.
What is this "jump" you speak of? Is that like shorting them or something?
I am very nervous at trying to do any kind of solder repair myself... fearing that I might short out the entire mother board causing it to be completely worthless.
Do you know of any reliable mail-in shops that can fix it for cheap? If not, I will just flat out sell the phone to someone that actually can do this repair. It's a shame, this phone is in amazing condition if it wasn't for that screen light.
Old 09-20-2014, 22:32   #4 (permalink)
Member: 1952487
Thanks Meter: 43
Hi, yes, "jump" is shorting 2 pads..
if you don't have any experience with that you shouldn't do it.
if you want, you can ship it to me, i will fix that for you ..
Old 09-22-2014, 01:32   #5 (permalink)
Member: 2024271
Where are you from Arvaser? Do you have website?
Old 09-22-2014, 19:13   #6 (permalink)
Member: 950002
Sonork: Laa Elaha Ellallah
Thanks Meter: 119
Originally Posted by IceNiner View Post
Hey fellas,
iphone 5s no backlight solution
Old 09-22-2014, 19:25   #7 (permalink)
Member: 425283
i cant entering in service mode with *#0011#
check lock status
Old 09-22-2014, 20:24   #8 (permalink)
Member: 425283
check lock status
Old 09-22-2014, 22:50   #9 (permalink)
Member: 1952487
Thanks Meter: 43
hello, i'm from Israel, no i don't have one.. if you want, send me private message here and we will keep talking there.
Page generated in 0.18083 seconds with 8 queries
