Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-15-2017, 18:25   #1 (permalink)
Member: 1422282
Thanks Meter: 23
Iphone 6 backlight trolling me
Got iphone 6, backlight driver was the problem, i decided to replace all circuit as diode was burnt out, i replaced all circuit, back light came, put phone together n after few minutes backlight went again. Checked anode linne filter which was ****n , replaced that again but no backlight, then i replaced backlight driver again, now PP_Lcm__bl cat1 line is short to ground, i removed the filter , backlight ic, and even though cap c2018 which is near to connector, but line is still short, any one got idea what could be the reason?
Sent from my iPhone using Tapatalk
Old 06-18-2017, 14:40   #2 (permalink)
Member: 2205919
Thanks Meter: 33
Check all capacitors on this line... not remove, replaced it. I had similar problem. When you remove capacitor your backlight diode or ic will burn. I think now you have to replace backlight ic. But remember to check all capaciotors and replaced if short. I hope this helps.
The Following User Says Thank You to mb83 For This Useful Post:
Old 06-18-2017, 19:37   #3 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
i ve recieved same a burnt diode from one side i hdnt repair it before need solution tht how to rebuilt circuit and part tht i ve to change
Old 06-18-2017, 20:14   #4 (permalink)
Member: 1422282
Thanks Meter: 23
Burnt diode is caused by anode line , most likely anode line gets short cos of three caps on the line. Check those caps and replace the faulty one n then replace diode , you ill get your backlight. Mine case was different, i had internal short in lcm cat 1 so i jumped that line ..
Old 06-18-2017, 20:16   #5 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
if donot replace the cap and change the diode will it burnt again ? bcose i dont hve another cap to replace
Old 06-18-2017, 20:18   #6 (permalink)
Member: 1422282
Thanks Meter: 23
It ill burn the diode again. You don't have any other donor board? Get cap from any dead donor board..
Old 06-18-2017, 20:19   #7 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
thnx i ll try it in morning and if the line is not short or the cap then i only have to change the diode
Old 06-18-2017, 20:21   #8 (permalink)
Member: 1422282
Thanks Meter: 23
Yeh, but that is highly unlikely, cos diode always gets burn cos of short as I explained before.. Good luck
The Following User Says Thank You to shani1122 For This Useful Post:
Old 06-19-2017, 19:18   #9 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
i ve change the diode replace the caps and tracks are ok but light in lcd
Old 06-19-2017, 19:39   #10 (permalink)
Member: 1422282
Thanks Meter: 23
You got backlight?
Old 06-19-2017, 19:42   #11 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
no
Old 06-19-2017, 19:43   #12 (permalink)
Member: 1422282
Thanks Meter: 23
Ah ****, then you need to replace backlight ic..
Old 06-19-2017, 19:59   #13 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
if it also doesn't work next step? bcoz its 2nd time trying to repair back light but didnt got succesful need proper solution
Old 06-19-2017, 20:19   #14 (permalink)
Member: 1422282
Thanks Meter: 23
That ill work 4 sure. I know its bit tough when you are new in micro soldering but thats how you learn. Try to wiggle out the actual problem. I got one phone same like yours today,i already replaced faulty cap and diode but still no backlight. i m also going to replace backlight ic tomorrow or after tomorrow. I
The Following 2 Users Say Thank You to shani1122 For This Useful Post:
Old 06-19-2017, 20:35   #15 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
shall i wait for ur result or try mine
Page generated in 0.24374 seconds with 8 queries
