06-13-2017, 15:17 | #1 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2643514 Status: Offline Thanks Meter: 28 | iPhone 6s No Touch Any help from professinals will be highly appricated. |
The Following 2 Users Say Thank You to mawaqas For This Useful Post: |
06-13-2017, 21:27 | #8 (permalink) | |
Freak Poster Join Date: Jan 2014
Member: 2106911 Status: Offline Thanks Meter: 67 | Quote:
this 2 days after backlight job and big audio ic remplacement . -test the resistor on top of your red mark you have to get theire 1V8_touch personally i don't get that voltage did you notice weird value one diode mode aon J4200 on pin 28 LCM_TO_CHESTNUT_PWR_EN_CONN when i shut down the phone remove battery the value on this one is very low and increase when the board get colder i dont have board to compare so only guessing | |
06-14-2017, 10:55 | #10 (permalink) |
Member: 2106911 Status: Offline Thanks Meter: 67 | hello i don't think it's connector issue for that you don't have to replace anything before proced by excluding things so first -check for filter visualy and beep mode -diode mode restisantance on each pads of the J4200 -then voltages in my case the PP1V8_TOUCH not present and the other even -so it can be several things Chestnut (for me i think at him first ) but chestnut provide LCM too so can it be half faulty ?? or caps on the messon line PP5V7_MESON_AVDDH , PN5V7_LCM_MESON_AVDDN from Chestnut (faulty,shorted ) can also be the AP_TO_TOUCH_RESET_CONN_L so you have to check filter FL4134 next to the J4100 Pmic (faulty ) but i doute or spi line Brocken (thats *****) please do those test seriously and reply your results |
06-15-2017, 10:25 | #11 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2205919 Status: Offline Thanks Meter: 33 | Bro read my posts... all of these things i did before. We dont have any new ideas so dont write you brilliant ideas becouse i check all of these in first place. I,m stuck, i dont know where to look. |
06-15-2017, 10:56 | #12 (permalink) | |
Member: 2643514 Status: Offline Thanks Meter: 28 | Quote:
thanks for your reply. I have tested PIN 14 at J4100 for PP1V8_TOUCH_ and im not getting 1.8V there also checked FL4134 and FL4131 both good Last edited by mawaqas; 06-15-2017 at 11:03. | |
06-15-2017, 11:24 | #13 (permalink) | ||
Check FL4105 for PP1V8_TOUCH mine is ****n. Im going to replace it and see if i get PP1V8_TOUCH | ||
06-15-2017, 12:17 | #15 (permalink) | |
thank you for your message .... i was stuck excactly on this too and i wanted to compare with others to see what i miss not trying to value my self !! you'r without a doute smarter than me so ... my only expectation was learning and sharing simple as that,you look for solution ,i look for brainstorming ,compare ,evoluate. so i will keep my brillante ideas for my self next time . as i always says and write that's not my job ,i do this only for fun . take care | |
