Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-08-2016, 18:57   #1 (permalink)
Member: 205933
Thanks Meter: 2
iPhone 6 No LCD
3 days after I change screen on iPhone 6 customer comes back with no LCD. There is also no backlight either. Where do I start to diagnose which chip is bad?
Old 08-08-2016, 22:30   #2 (permalink)
Member: 2608253
Thanks Meter: 4
1st, make sure the phone isn't simply in recovery mode (connect it to iTunes).
If you're sure of this, next is to see if it's a display issue or a no-power issue. When you connect it to iTunes you will know; if it's detected by iTunes then the board has power.
After that, check the voltage on C1547 and make sure it matches VCC_MAIN's expected voltage. Also check C1541, C1569, C1577, C1504 for continuity to ground and correct voltage. The first 3 (1541, 1569, 1577) should have 5.1V, the next (1504) should have 5.7V.
If C1547 has good voltage but one or more of the other capacitors does not then you have a bad Display PMU (U1501). If all of the capacitors you tested are short to ground then that also means U1501 is bad.
Let me know what you find out.
Old 01-17-2017, 10:53   #3 (permalink)
Member: 2555986
backlight
Hello,
i have a phone with no backlight (changed burnt C1552 & C1597), now have 4 volts up to connector but no 5.7 volts from u1501.
There is 4 volts on C1547, would this point to a fault with U1501 & would the missing 5.7 volts cause the backlight issue.
I can see the phone working when i shine a light on the dark screen.
Thx
The Following User Says Thank You to dr_goppo For This Useful Post:
Old 01-17-2017, 17:37   #4 (permalink)
Member: 2515187
Thanks Meter: 114
Originally Posted by dr_goppo View Post
Hello,
Thx
Hello
Backlight problem not the U1501. It's U1502, D1501, C1505, C1530, C1531 and the corresponding filters problem.
The Following User Says Thank You to Pallle For This Useful Post:
Old 04-09-2017, 13:29   #5 (permalink)
Member: 2374221
Hi, need experts help please!
Same problem here whit missing 3 lines
PN5V7_SAGE_AVDDN on C1504
PP5V7_SAGE_AVDDH - C1577
PP5V7_LCM_AVDDH - C1569
I have presend only PP5V1_GRAPE_VDDH 5.04V and PP6V0_LCM_BOOST - 6V
replaced U1501 4 times 2 new and 2 form donor boards every time same result
Old 04-09-2017, 16:31   #6 (permalink)
Member: 2374221
aha lcd must be connected! if not to measure them you have to inject 1.8v form somewhere to LCM_TO_CHESTNUT_PWR_EN
The Following User Says Thank You to zakvoline For This Useful Post:
Old 04-09-2017, 18:05   #7 (permalink)
Member: 2226403
Thanks Meter: 32
sometime copy lcd makes such type of cause or two screw over lcd bar also makes such type of fault
Old 06-01-2017, 17:21   #8 (permalink)
Member: 1528845
Thanks Meter: 6
Hello, i have an iphone 6 with no display
voltage on C1547 = 4,1v
matches VCC_MAIN's expected voltage = yes
C1541 =5,04v
C1569 = 0v
C1577 = 0V
C1504 = 0V
no short to ground! could the be u1501? pleas help, thanks
Old 03-13-2018, 14:26   #9 (permalink)
Member: 202617
C1541 =5,04v
C1569 = 0v
C1577 = 0V
C1504 = 0V
Have you fixed the issue? I have faced the same trouble, but I have C1569 - 4,06v not enough, must be 5,7v And of course I had changed U1501 for the working one.
Old 03-13-2018, 19:33   #10 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
What was the original problem?
Backlight is present or not?
Old 03-21-2018, 13:18   #11 (permalink)
Member: 1219201
Thanks Meter: 3
i have the same problem. anyone got it fixed? need help.
Old 03-21-2018, 16:37   #12 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Post all outputs of U1501 to help you and give info what cause the problem.
Old 03-22-2018, 08:13   #13 (permalink)
Member: 1219201
Thanks Meter: 3
supplies are ok but no voltage after turning it on.. no voltage on PP5V7_LCM_AVDDH and PN5V7_SAGE_AVDDN
Old 03-22-2018, 10:31   #14 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Check LCM_PWR_EN and I2C rails of 1501. If there is no test points you need to remove again.
Old 02-12-2025, 15:33   #15 (permalink)
Member: 383968
Hello.
I have an iPhone 6S plus with no image, I'm suspecting an internal short inside the LCD assembly.
Could somebody please help me out with a quick measurement? (LCD flex connector)
I need the resistance to GND of pin 49 (PP5V7_LCM_AVDDH_CONN) on the LCD cable connector. (not the motherboard)
I don't have a replacement screen to test with, and on mine that pin is 5 Ohm to ground. I would really appreciate any help. (the 2 metallic ends of the LCD flex connector are GND)
Thank you!
Page generated in 0.22373 seconds with 8 queries
