IPhone 6 no touch even after replacing both touch IC's hi guys i have an iphone 6 touch issue, no water damage but maybe dropped not sure what done so far replacing U2401, U2402,U1501, checking voltages all present only one voltage is missing PP5V1_GRAPE_VDDH also there is no short or low reading on this line and i checked from under U1501 to under U2401 and it's connected, any idea please? thanks |
check all capastors between the touch ics...you will find solution |
Do you think the 5V for PP5v1_GRAPE_VDDH is missing because of those IC's? Anyway will check tomorrow morning hope i find a faulty cap there |
Regards Sent from my SM-G935F using Tapatalk |
just checked and found these voltages PP1V8_GRAPE and PP_CUMULUS_VDDCORE and PP_CUMULUS_VDDANA are missing i checked the lines no short or low readings so i reball and replaced the Power ic but still no PP1V8_GRAPE. any Ideas??? |
hello did you repeal and replace your PMIC or juste reball and replace ?? (to make that touch work again ;-p) |
for the PP1V8_GRAPE it can be the U2403 shorted or bad or your cumulus shorted or bad check also your CUMULUS_TO_PROX_TX_EN_BUFF on Q1101 and R2407 near the U2403 |
U2403 and U2401 been replaced still no touch |
i have 3 iphone 6 the same problem no touch screen i changed u1501 and both ic touch but not solution pp 5v1 grape is 0v |
Check CUMULUS_TO_SAGE_BOOST_CLK_EN TOUCH_TO_SAGE_VCM_IN_CONN |
