03-08-2016, 04:08 | #1 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2537858 Status: Offline Thanks Meter: 34 | iphone 6 plus no touch I have an iPhone 6 plus with no touch problem. I changed both touch IC's but still no touch. I checked connectors and they are fine. I tried a new display and same problem, no touch and some horizontal lines. What can I check? Thank you. |
03-11-2016, 01:32 | #3 (permalink) |
Member: 2537858 Status: Offline Thanks Meter: 34 | I checked the touch pins, some of them that should be grounded are not, and some that shouldn't be ground are. Anyone have iphone 6 plus .pcb file that can share? I have one but it does not 100% match the components. |
03-12-2016, 01:38 | #4 (permalink) |
Freak Poster Join Date: Sep 2008 Location: U.S.A
Member: 856640 Status: Offline Sonork: 100.1606320 Thanks Meter: 281 | just try again to change the line touch controller IC... sometimes IC is defective.got experience change 3x no luck. but on the 4th time success. |
03-12-2016, 21:09 | #5 (permalink) |
Member: 2537858 Status: Offline Thanks Meter: 34 | Guys, I think I found the cause of the touch problem, PP_SAGE_TO_TOUCH_VCPH_CONN pin 36 of the touch connector is grounded, this is a power line and should not be grounded, I checked on zxw tool but I can't find the cause of the short. Any one has experience with this problem? Thank you. |
03-12-2016, 21:55 | #6 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: Apple Age: 35
Member: 1918158 Status: Offline Thanks Meter: 177 | Quote:
... Chek all cap on conecter may be short anyone Many time i solved this problem Chek bord with microscop clearly | |
03-14-2016, 10:23 | #14 (permalink) | |
Junior Member Join Date: Mar 2016
Member: 2544878 Status: Offline Thanks Meter: 0 | Quote:
I hope that it will help you. I can't post link's. Just search google for this aTujSKxM4Vg . Thank's . | |
03-14-2016, 22:37 | #15 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Hungary
Member: 2515187 Status: Offline Thanks Meter: 114 | [QUOTE=jojojiji;11689493]I already checked in zxw for r2412 but it does not show any other connections. only the one is red that I posted in the picture...[QUOTE] Hi The other side of the r2412 go to c2440 and u2402. Remove c2440 and check. |
