iPhone 6 Plus not charge Received one iPhone , customer is taxi driver and most time he charge the iPhone in the car, but there is a problem with the car power supply and damaged , I think probably iPhone have received 12V , don’t know. Now iPhone when have charge is working normally , but when full discharge if i Connect the charger phone not start charging. With the phone powered on if I connect the charger phone have a consumption 10mA but this consumption only start if I introduce the code to unlock the iPhone and sometimes when I insert usb cable there is a message “unlock the iPhone to access accessories” , if I connect to computer he not detect nothing , if I power off the consumption goes to 380/400mA oscillating but not apear in display any message is charging and in fact not charge nothing. I have replaced the battery, and port connector but problem is the same. |
You have to change tristar. Use a quality car charger. |
What you mean tristar? The Mercedes have incorporated an factory module 12v to 5V converter and is used the original Apple usb cable to charge. There was some problem and converter is damaged and caused this fail in iPhone. |
