Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 04-05-2016, 09:16   #16 (permalink)
Member: 1752885
Thanks Meter: 4
Originally Posted by jimchu316 View Post
Through this picture, you can find 2 places to measure -5.7v
one near U2402, other near U0900
could you share the PCB Files for PADS
Old 04-05-2016, 10:48   #17 (permalink)
jimchu316's Avatar
Member: 2252373
Thanks Meter: 400
sorry, i canot share our company files to u.
Old 04-05-2016, 10:48   #18 (permalink)
Member: 1752885
Thanks Meter: 4
ok, no Problem. Thanks
Old 05-16-2016, 03:31   #19 (permalink)
Member: 2380252
I've checked the -5.7v near the U0900 but I get nothing even with a good working phone. Do I need to connect battery and LCD screen to get the -5.7v? I have just the charger plugged in with no LCD. Please help.
Old 07-30-2016, 11:54   #20 (permalink)
Member: 463420
Thanks Meter: 150
replaced u2402 but nothing
check redline way.
I would like to know what kind of software is that? the name of the box or application. Thanks.
Old 07-30-2016, 11:55   #21 (permalink)
Member: 463420
Thanks Meter: 150
check redline way.
Thanks
Old 07-31-2016, 05:22   #22 (permalink)
Member: 278546
Thanks Meter: 145
bro remove all 2 touch ic and check if u still get lines cpu problem , note after remove ic only vertical water marl lines appear. not like your image.
Old 07-31-2016, 10:37   #23 (permalink)
Member: 2277735
Thanks Meter: 215
Have you tested the screen on different logic board?
Old 08-27-2016, 19:54   #24 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
4, check u2402 M1 pad
This is not M1 pad but L1 pad.
Old 08-30-2016, 13:01   #25 (permalink)
Member: 2080974
Thanks Meter: 12
Reball u2402, clean the pcb pads first
Old 08-30-2016, 17:06   #26 (permalink)
SAEIDSANGAN's Avatar
Member: 1691551
Sonork: 100.1622582
Thanks Meter: 53
replace black ic touch
Old 11-01-2016, 10:40   #27 (permalink)
Member: 1429407
hi i replace ic but same problem no display no light blank lcd
Old 12-15-2016, 12:38   #28 (permalink)
Member: 781426
Thanks Meter: 17
jimchu316 is correct, just replace u1501 if you have line & can't touch, i've fix that many times.
base on what i encounter, motherboard is clean & no other repair.
Old 12-29-2016, 11:56   #29 (permalink)
Member: 1291319
Thanks Meter: 3
1, check touch screen socket j2401
2, check DC 1.8v, 5.1v, 5.7v, -5.7v
3, check u2403
5, replace u2402, u2401
6, cpu
if i can't get 5.1v..what should i do..i means what ic that produce 5.1v..is it u1501 or else..if u1501, replace or i can just rehot
The Following User Says Thank You to demyth For This Useful Post:
Old 01-06-2017, 19:40   #30 (permalink)
Member: 2643514
Thanks Meter: 28
have you tried a different working LCD? happend to me a few times. the fpc connectors are not seated properly.
Page generated in 0.24773 seconds with 9 queries
