Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-09-2018, 21:59   #1 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
Unhappy ICLOUD remove IPADS 3G TO WIFI - NOT Possible anymore???
Hello friends,
I have A1490 ipad mini 2 3G CELLULAR AND WIFI MODEL
I made it wifi model by removing resistors FOR REMOVING ICLOUD
I bOUGHT bluetooth wifi and serial and wrote on NAND
I verified all SERIAL WIFI BLUETOOTH IN 3UTOOLS and all is OK
Ipad restored good
now ipad is not activating and giving error
I BOUGHT WIFI SERIAL BLUETOOTH 2 TIMES FROM 2 SOURCES STILL
NOT ACTIVATION
why?
APPLE IPAD 3G CELLULAR NOT POSSIBLE REMOVE ICLOUD ANYMORE??
Old 06-10-2018, 02:20   #2 (permalink)
Zaki Bouzidson's Avatar
Member: 2287326
Thanks Meter: 54
I rely on both of these free services, check your serial number if it’s really for iPad mini 2 model because there’s some incompatibility which I don’t know about. Last time I bought and tried many SN for iPad mini 4, none of them seemed to work until I used mini 1’s SN. Hope this could help you, good luck!
http://iunlocker.net/check_imei.php
https://ifreeicloud.co.uk/free-check
The Following User Says Thank You to Zaki Bouzidson For This Useful Post:
Old 06-10-2018, 03:17   #3 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
Question
i have just tried 3rd serial from other ipad mini2 WIFI MODEL ( dead donor board) and it wont activate,
For information - All serials I used before are clean and are from IPAD MINI2 WIFI ONLY
Old 06-10-2018, 03:26   #4 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
Question
I checked and all serials are from IPAD MINI2
I have also used SERIAL WIFI AND BT FROM DONOR IPAD MINI2 board
and still not activating
Maybe something with ios 11.4?
Question for you -
When was Last time you removed ICLOUD on ipad mini 2 cellular or any other model?
Thank you
Old 06-11-2018, 20:32   #5 (permalink)
Member: 2277735
Thanks Meter: 215
Try changing board, colur, area in nand settings, I hear some pplnees to make shore these are coreect then will activate, even nand make might need to be the same!
Old 06-11-2018, 22:01   #6 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
NaND i already changed to other one because the ORIGINAL NAND broke.
I will try changing color, area etc
- And, when was last you removed ipad cloud successfully on ios 11.4 (not ipad mini1)
Old 06-11-2018, 22:28   #7 (permalink)
Member: 2277735
Thanks Meter: 215
Not on 11.4,11.3 was last try, i will try soon but no pads to test on at moment
Old 06-14-2018, 01:42   #8 (permalink)
Member: 201359
Sonork: 100.1607870
Thanks Meter: 128
I just done ipad air just wifi model with last ios all good no provlem in activation
Old 06-14-2018, 08:59   #9 (permalink)
Member: 2277735
Thanks Meter: 215
Lol not ipad 1, i try to help you and come back with that.... Like i said make model area will make the diffrence in activating or not, same for IOS 9,10,11..
I have a navi 3000s so know what im talking about so dont undermine me by coming out with a silly reply when all i was doing was trying to help!
Old 06-16-2018, 10:11   #10 (permalink)
Member: 2287326
Thanks Meter: 54
If nothing is wrong with the latest iOS update then it is time for some measurements!
Make sure you did the logic board conversion the right way, maybe something’s not good with a resistor even when it accepts the Wi-Fi model firmware.. you never know!!
The link for the official method by pasha4ur is here
Old 06-16-2018, 16:17   #11 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Thanks Meter: 523
Smile
I did one mini3 LTE 3 days ago without problems.
Old 06-16-2018, 16:27   #12 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
hello.
i did not mean in other way, sometimes I make typing mistakes too.
i have IPox latest version
i will try changing
- Area
- color
- Model i have already tried changing before.
I appreciate time you are taking to help me out
The Following User Says Thank You to christina_ For This Useful Post:
Old 06-16-2018, 19:51   #13 (permalink)
rogerboogie's Avatar
Member: 103024
Thanks Meter: 616
Contact me on prívate i could help
Whatsapp +525524958894
Facebook. Roger house
Old 06-16-2018, 21:15   #14 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
Check your whatsapp plz.
thx
Old 06-18-2018, 23:47   #15 (permalink)
Member: 1034062
good evening
I have a mini ipad a1600 I did all procedure bypass via hardware it is not activating
Can someone help me
Page generated in 0.23706 seconds with 8 queries
