11-03-2015, 06:11 | #33 (permalink) | |
Junior Member Join Date: Nov 2014
Member: 2301166 Status: Offline Thanks Meter: 0 | Quote:
More simple, If u Don't have another batt, turn On iPhone use pwrsupp, If still restart, cek from battery Ways, Don't forget check voltage, Sent from my iPhone using Tapatalk | |
12-06-2015, 11:43 | #38 (permalink) |
No Life Poster Join Date: Sep 2009 Location: 9ja
Member: 1110430 Status: Offline Thanks Meter: 104 | Pls help any working solution to the iphone6 that it touch screen not working after testing with several touch screens.The panel is even put in another housing still not touch. thanks in advance. |
12-23-2015, 02:55 | #44 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1241588 Status: Offline Thanks Meter: 0 | Confused. Am i too short the two pins for the transistor that you showed in post 25. Or replace the IC's So this is if the phone doesnt respond to being plugged in at all. I plug the phone in, and the phone doesnt recognize that it infact has been plugged in. No iTunes, and it doesnt charge at all. Mjr |
12-24-2015, 09:40 | #45 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1559756 Status: Offline Thanks Meter: 0 | Hi to all. I have a problem with my iPhone 6. At first the screen was very dark almost impossible to see and then it went out completely. The display is working perfectly because I tried it on other iPhone. Also Tried to restore but I got Error 53 (with original Touch ID) I think it is because I to restored without the display working. Followed you guide to check the coil and diode with multimeter but I have trouble doing it because I am beginner and the parts are too small. Is it better to remove the motherboard and turn it upside down so I can check it? And also are there any possible ways to check the chip if it is working? Thank you for the great post! |
