iphone 6 won't turn on I have an iphone 6 that won't turn on! On diode mode i get: 1.5V at battery fpc connector 1.5V pp_vcc_main 1.5 pp_batt_vcc can some help me? Thanks |
Put phone in charge and check: 1. Battery connector for 3.8v 2. If battery connector not 3.8v, check C1704 for 5v 3. If C1704 not 5v, check Q1701 |
Yeah ninos22 said right. Nspereira you can try it. if can't work, guess somebody else will help you soon. |
1. 1.5V 2. C1704 - 1.5V 3. Q1701 - 2.2V What should i do next? Thank you! |
C1704 , Q1701 and C1408 - 2.6V |
Check PP_BATT & VCC_MAIN with diode mode |
VCC_MAIN - 1.5V what should i do? remove the PM IC? |
max value in diode mode is 0.99 red to ground black to components |
Ok so what is the value in diode mode? |
1.2V for PP_BATT - C1480 1.5V for PP_VCC_MAIN - C1418 |
can someone help me? |
