Iphone 6s/7 disassemble and reassemble complete teardown for repairing hi guys today i am going to guide you about iPhone 7,in which i would like to show you about all accessories and how to remove and refit them iphone 7 and 7 plus are same to disassemble THE MAIN WIEW http://i.imgur.com/NymqyeW.png STEP 1: in this step you can see that you must remove two 3.4 mm screws with a fine screw driver same like iPhone 6 or 6s on the bottom edge of iPhone 7 http://i.imgur.com/tGdABoC.png STEP 2 before you use suction cup to remove the display please use hot air for 10 seconds carefully to not demenge display then carefully use suction cup and a plastic stick to remove display http://i.imgur.com/ZAqVLt1.jpg STEP 3 now lift up the display slowly not more than 10 grade because there are ribbon cables on the right edge http://i.imgur.com/9VBVWwz.jpg STEP 4 pull up the display from left side to upwards like to opne a book carefully otherwise you can damage front camera and touch cables are still connected in the right side of motherboard http://i.imgur.com/oaIzXcH.jpg STEP 5 now remove all screws which are highlighted and there are tow types of screws 2.4 mm and other are 1.2 mm,be careful to not exchange the screws http://i.imgur.com/QDKBIcB.jpg [B]STEP 6 now remove also other two screws size 1.3 mm and becareful to not exchange these to other screws to avoid to damage screw holes and motherboard http://i.imgur.com/dvHHrQ1.jpg STEP 7 now remove the display assembly carefully http://i.imgur.com/6Uxc796.jpg STEP 8 now here remove the 1.9 mm screws and put them carefully separate from other screws http://i.imgur.com/U7ir6qn.jpg STEP 9 remove 1.6 mm screws to remove TAPTIC ENGINE http://i.imgur.com/M23j5K9.jpg over i have told all about to remove display you must be careful to remove all the parts and refit them and i recommend to all friends to never exchange the screws Ii have tried my best to make this thread and hope that it will be helpful to all hardware friends if you like the thread only press thanks button |
here i am loading all components of iPhone 7 http://i.imgur.com/rCRJ8gd.png http://i.imgur.com/aaR9clw.jpg http://i.imgur.com/PTkJGPP.jpg http://i.imgur.com/ovRTmqo.jpg http://i.imgur.com/JGhJkf0.jpg http://i.imgur.com/NyoZWi5.jpg http://i.imgur.com/06uatu4.jpg http://i.imgur.com/WDlznCn.png http://i.imgur.com/nTwv3Wj.png http://i.imgur.com/TYGRQBj.png http://i.imgur.com/rdFdsdN.png http://i.imgur.com/YDl0uhL.png http://i.imgur.com/F67Y34H.jpg http://i.imgur.com/s3674o6.png i hope that the thread will be helpful to all friends if someone needs more info can write me frankly in this forum if you like pleas press only thanks button |
iPhone 6s today i am going to update some more information abut iPhone 6s first of all when you are going to flash your iPhone check if 1: the the cable is genuine 2: your iTunes software is up to date 3: the firmware you are going to put on is latest and not corrupted http://i.imgur.com/e5gTV4h.png here i am going to show you all the components of device all the images are down here together and the components of 6 and 6s are almost same http://i.imgur.com/16g5hWd.png http://i.imgur.com/A154eQA.png http://i.imgur.com/70XKwVK.png http://i.imgur.com/A154eQA.png http://i.imgur.com/0dU8F1a.png http://i.imgur.com/d5pazVi.png http://i.imgur.com/ZeHLFEZ.png http://i.imgur.com/0rC2PYf.png http://i.imgur.com/wR8j7V7.png http://i.imgur.com/G5RZmZQ.png http://i.imgur.com/5206ZPz.jpg guys i have tried my best to provide you the best info about all components to help all iPhone 6s hardware friends if somebody has images to share to help others can send me and i will try to upload on forum if someone wants schematics of Apple_iPhone_6S_N66 can download under here click here : download if like this thread kindly only press thanks button |
hi friends, here i am sharing some more images to help you and would like to ask if someone has something to help other can share with me but it must better info to help members http://i.imgur.com/1zXoYF1.png http://i.imgur.com/9Guuv0y.png http://i.imgur.com/ZZAKycu.jpg http://i.imgur.com/KWnyWFZ.jpg |
Cool! But this action will spoil the warranty. |
