12-09-2016, 23:50 | #1 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1191636 Status: Offline Thanks Meter: 6 | Iphone 6s nand error 4014 I have iphone 6s error 4014 I replace the nand flash from iPhone icluod It's work OK but not active In restore with iTunes Not. I don't have programmer nand |
12-11-2016, 21:11 | #5 (permalink) |
Member: 1191636 Status: Offline Thanks Meter: 6 | Thanks I have iphone 6s error 4014 I replace nand flash .I take the nand flash from iPhone icluod Then restore with iTunes ok But at finally error message not active this iphone. |
12-11-2016, 21:21 | #6 (permalink) |
Freak Poster Join Date: Dec 2014 Location: PCB
Member: 2320407 Status: Offline Thanks Meter: 88 | this is because of SN incompatible with new IMEI ! so you need to reprogram the NEW NAND or try reball old NAND because of APPLE security you can only change components you are forbidden to replace the following NAND,CPU,BB-CPU,eEEprom,fingerprint, WIFI ! I am a Signal-level technician ! regards |
12-11-2016, 22:59 | #7 (permalink) | |
Freak Poster Join Date: Mar 2013 Location: Greece Age: 35
Member: 1903358 Status: Offline Thanks Meter: 146 | Quote:
01-12-2017, 12:57 | #10 (permalink) | |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Quote:
You can also order a pre programmed nand from aliexpress. Some seller do this service. You give them your serial number and they will put it for you in the nand. This way you only have to replace it an dont need to by expensive NAND programmer. | |
The Following User Says Thank You to timvandenboo For This Useful Post: |
02-07-2017, 01:44 | #11 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | I had an iphone 6s with 4014. C1515 was shorted next to the nand. I removed the shorted caps and the phone came out of DFU mode and back alive. Hope my experience will help some of you. |
The Following 2 Users Say Thank You to HDccam For This Useful Post: |
05-30-2017, 10:40 | #13 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2703838 Status: Offline Thanks Meter: 0 | I also changed NAND and copy data by using WL PCIE NAND tool. But when I put my iPhone into DFU mode, just after few apple logo showed up it turned off. Then iTunes says error 4014. Is that a same problem everybody talked above? Maybe when I remove NAND I gave a damage to right side of nand. There's very small parts. I removed C1515 but no change. You guys' help would be greatly appreciated. |
