12-01-2016, 19:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | Iphone 6s plus Error 9 While Updating Has anyone ever encountered this issue in 6s plus? |
01-19-2017, 08:44 | #8 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Earth
Member: 813803 Status: Offline Thanks Meter: 120 | Solution : 1. Update iTunes to last version Then test 2. Try restoring with different USB port Then test 3. Your USB cable must be original or if not original, make sure the cable can restore another phone Then test 4. Check the battery connector if damaged, replace Then test 5. Change your battery Then test 6. Try restore with different charging dock flex Then test 7. Heat NAND IC 300C for 20 seconds, and quickly try to restore (This is temporary trick if problem is nand) 8. Replace NAND If nothing works, throw phone on the road and let a truck run over it |
01-19-2017, 08:52 | #9 (permalink) |
Member: 813803 Status: Offline Thanks Meter: 120 | Also, on windows open up a Run box (Win Key + R), type %appdata% and press enter, your appdata folder will open. go to (Roaming>Apple Computer>iTunes>iPhone Updater Logs) and copy the latest log and paste it here, that will allow me to help you better. |
01-19-2017, 09:01 | #10 (permalink) | |
Insane Poster Join Date: Nov 2010 Location: ******
Member: 1456151 Status: Offline Thanks Meter: 8 | Quote:
good this evry thing | |
The Following User Says Thank You to unlockergsm2010 For This Useful Post: |
01-19-2017, 09:53 | #11 (permalink) |
No Life Poster Join Date: Nov 2015 Age: 25
Member: 2493574 Status: Offline Thanks Meter: 605 | AN uNKNOWN ERROR OCCURRED-9 THIS IS A SOLUTION FOR ALL IPOD/IPHONES (ANY IOS VERSION) FOLLOW STEP CAREFULLY WHEN YOU GET ERRO OCCURED 9 WHEN RESTORING .BLA BLA.. CLICK OK AND SHOW IPHONES SOFTWARE UPDATE CLICK OK AND CLOSE ITUNES DISCONNECT YOUR IPHONE FROM USB CHORD open task manager goto processor and find there itoolsDaemon.exe*32 end process after that tick to showprocess from all users and again find Applemobiledevicesservice.exe hit end process after find ipodService.exe hit end process ipover usbsvc.exe*32 hit end process now come to itunes open it connect your iphones with computer and force it to DFU MODE BY PRESSING HOME AND POWER BUTTON UNTILL YOU HERE SOUND FROM YOUR COMPUTER .NOT IN RECOVERY MODE AFTER that iTunes not detect your iPhone in iTunes mind phone should be in dfu and single steps from above to below should not be missednow disconnect USB power chord not from phone but the power chord from computer and move to another USB chord not used before anymore with Iphones now iTunes detect your phones but it shows recovery mode even you were in dfu mode now go on process of software update it will be now fine post your result here thankyou |
The Following User Says Thank You to Shikhar12 For This Useful Post: |
02-22-2017, 10:21 | #12 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Sri Lanka
Member: 164422 Status: Offline Thanks Meter: 24 | itunes error 9 on 6s i too face the same issue error 9 while restoring iphone 6s and tried all the solutions given none of them worked.i even tried heating the hard drive but still the problem remains same.Anyone have a working solution plz post |
