01-18-2017, 23:24 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Denmark
Member: 1839857 Status: Offline Thanks Meter: 46 | iPhone 6s replacing WiFi module I've started to run into more and more 6s with WiFi modules shorting main, but I haven't been able to successfully replace the module yet. Always did matching chip numbers, measuring all voltages correct, and had BT and WiFi address' in settings, but still grayed out WiFi. Researching this i found that in 6s the WiFi module and the NAND are paired up somehow. How do one go about solving this? I assume I need a NAND programmer - I was gonna get one eventually anyways, so might just buy it now. Which one to get? And what will I have to update/change in the NAND? All input or information is welcome, thanks! |
01-19-2017, 11:14 | #3 (permalink) | |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Quote:
iPhone 6S wifi ic can replace if you also remove NAND. Then use a PCIE programmer to remove the wifi numbers / bluetooth number in the NAND. Place the nand and the wifi ic back (new wifi ic) and nand will automatically recieve the new wifi codes. Youtube video: https://www.youtube.com/watch?v=3d8xm6oxkbo&t=366s | |
The Following User Says Thank You to timvandenboo For This Useful Post: |
01-20-2017, 12:11 | #5 (permalink) |
Member: 1839857 Status: Offline Thanks Meter: 46 | All the information I needed in a few replies - solid guys! Thanks, I'll be ordering the programmer and will post results here once the module has been successfully replaced! |
The Following User Says Thank You to jegerjon For This Useful Post: |
11-29-2017, 07:06 | #9 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | No it won't. To be able to program PCIE Nand Chips you need to purchase a programmer from Wl, JC or Mijing. All of them are good. All of them kind of do the same job. But WL PCIE programmer has good built quality and less complicated easy to use GUI. Hope that helps. |
