Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-11-2017, 04:29   #1 (permalink)
Member: 2777379
Thanks Meter: 34
iPhone 6 hangs at 200mA
Got an iPhone 6 that had a full VCC MAIN short and it's been removed, now drawing 0mA when off, once I power it on it starts to boot and gets stuck at 200mA and keeps drawing in that range forever, only the CPU gets slightly hot but I'd think it's normal,
What should I test to find the problem? thankkkkkkk you
Old 11-11-2017, 21:02   #2 (permalink)
Member: 2515187
Thanks Meter: 114
Hello
Try replace U1700.
The Following User Says Thank You to Pallle For This Useful Post:
Old 11-12-2017, 16:06   #3 (permalink)
Member: 2498972
Thanks Meter: 33
If the phone hangs during the boot process, that means a critical sub-system is failing. Start by checking the voltage rails generated by the PMIC. Check for shorts and proper voltage. That may help you isolate which subsystem is failing rather than randomly swapping components...
Old 02-24-2018, 00:54   #4 (permalink)
Member: 2604044
Hangs at 200mA
Had the same problem.
Connecting USB power also wasn't switching 100% from DC power supply.
Replaced Tristar and now fixed.
Old 03-16-2018, 14:10   #5 (permalink)
Member: 1313139
Sonork: Ghost
Thanks Meter: 6
0.200 0.250 MA always u2
Old 03-16-2018, 19:53   #6 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
No need to replace anything before confirm if working properly.
1. Plug usb and check BATT_VCC
Post result
Old 11-27-2022, 10:20   #7 (permalink)
Member: 599037
Thanks Meter: 103
Post result
3.74v on battery connector, while battery is disconnected
Old 11-28-2022, 20:59   #8 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Tristar is ok, you don't have to replace it.
What is your problem?
Old 02-03-2023, 12:21   #9 (permalink)
Member: 2816075
Thanks Meter: 8
Hello
Iphone stuck at 200mA sounds like he's in DFU mode.
Try to connect to itunes witch a charged battery
Page generated in 0.16795 seconds with 9 queries
