03-16-2018, 19:42 | #1 (permalink) |
Junior Member Join Date: Sep 2012 Location: Ukraine
Member: 1810243 Status: Offline Thanks Meter: 1 | Help please iphone 8plus layers Thank you |
09-14-2021, 12:14 | #2 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2872060 Status: Offline Thanks Meter: 0 | Hi Did you finally do the repair ? I have the same PB on a motherboard How did you found out that deep connection layer were touched ? I am ordering parts for it but the FL3995 is hard to find FL3995 = 10 ohm 750 mA 01005 C7606_W = 0.01UF 6.3V X5R 10% 01005 |
09-14-2021, 13:14 | #3 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | use a short killer to burn it to remove the short enject voltage in vcc main not in batery terminal this connection is just in the surface..maybe if its burn until 5th layer you will not have back camera..and mostly you need to reball wifi and make new connection of vcc main to wifi to make wifi work |
09-16-2021, 06:01 | #4 (permalink) | |
Junior Member Join Date: Jun 2016 Location: India
Member: 2583697 Status: Offline Sonork: 100.1677424 Thanks Meter: 21 | Quote:
09-16-2021, 08:59 | #5 (permalink) |
Member: 2872060 Status: Offline Thanks Meter: 0 | Hi Thank you for your reply, the short has already been removed. I do not have a short killer, it's kind of scarry for me. I have seen video, that's all. I also have 2 caps on an iphone 8 Intel called C147 and C148 but cannot find their values and can only see them on the Bitmap but not on the schematics. Unless there is an error on my Bitmap If someone could check for me it would be great |
