Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-27-2019, 21:28   #1 (permalink)
Member: 2736155
Thanks Meter: 10
Question About mdm remove ( not bypass)
Can anyway give me the responsible ic of mdm lock ?
I need to know where to find that ic or how to remove mdm lock forever because bypass mdm is not a solution actually
Old 08-28-2019, 10:53   #2 (permalink)
Member: 2136393
Thanks Meter: 9
There is no IC responsible for MDM. It's server based (like iCloud). I think only the company that put MDM on the phone can remove it (as far as I know but I may be wrong)
Old 08-28-2019, 17:10   #3 (permalink)
Member: 2736155
Thanks Meter: 10
It could be a resistor or something like that... Like icloud remove for ipad gsm
The Following User Says Thank You to Aymen2net For This Useful Post:
Old 09-02-2019, 19:48   #4 (permalink)
Member: 2162802
Thanks Meter: 15
try sickw. cost is around 22. i have not tried it yet through this site. but i use it regularly for other items that are listed.
Old 09-04-2019, 20:58   #5 (permalink)
Member: 72939
Thanks Meter: 30
sickw is still a bypass only, had mine done on ebaY FOR $1.50
Old 10-10-2019, 01:18   #6 (permalink)
Member: 1678953
Thanks Meter: 67
as it was said the lock is on apple's server side and there is not a resistor on the mother board which can help , there are only two ways to use the ipad ;
1 bypass mdm which you do not like, i do not like it too
2 reprogram the nand with a valid sn wifi bt, and if it is a cellular one you must convert it to wifi and replace the wifi ic if needed, then restore it and you are done
i hope this is clear to you
Page generated in 0.15273 seconds with 8 queries
