Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-28-2019, 00:01   #1 (permalink)
Member: 1319762
Sonork: krisszmix
iPhone 7 no sound during the call (ic replaced!)
Helo All !
I have a special problem, with an iphone 7.
Every speaker is working, i hear the ring, i hear the dial sound. No grey icon !
But if i get a call, no sound any speaker. Just in the call time. When the call period is end, the sounds come back.
I reballed the audio ic, i replaced twice! I reballed the two audio amplifier ic (U3402/U3502). Nothing change. I check any ic pads !
I do not have "loop disease" problem, and i do not have Gray call icon problem.
I check another Main Flex cable, but nothing change.
I put the motherboard, an another good housing, but nothing change.
I repaired many iphone 7 audio ic, but i do not heard this problem.
Can anybody give me an good idea ?
Old 10-28-2019, 06:54   #2 (permalink)
Member: 2766946
is your mobile time ok?
Old 10-28-2019, 09:03   #3 (permalink)
Member: 1939450
Thanks Meter: 158
What i found on the iphone 7 so far is that when i got this problem it originates mainly from a broken pad. Even if they "beep".
For the intel iphone 7 mainly the classic pad is broken. Which is the one close to the side. For the quallcom unit it are mainly the other 3 pads that are ripped.
Just make a jumper on them to be sure. And check again if solved.
Old 10-28-2019, 10:46   #4 (permalink)
Member: 1319762
Sonork: krisszmix
Helo !
Yes, the time is ok, and i did software update with itunes, and i did factory/full reset...
Nothing change..
Old 10-28-2019, 17:23   #5 (permalink)
Member: 2094358
Thanks Meter: 2
it seems ic audio u need to change it
Old 10-28-2019, 22:38   #6 (permalink)
Member: 1319762
Sonork: krisszmix
Helo !
But, i reballed the original ic..
And then replace an brand new ic, then replace again an new ic...
It is 3 ic. Would be bad all the 3 ic ?
Old 10-29-2019, 09:18   #7 (permalink)
Member: 1939450
Thanks Meter: 158
Originally Posted by krisszmix View Post
Helo !
But did you make jumpers on pads????
Old 10-29-2019, 23:27   #8 (permalink)
Member: 1319762
Sonork: krisszmix
No, i did not make the jumpers because, before every ic replace, i check the pads with multimeter and with Zillion diode resistance value. So i make three metering, with the three ic replace. And i had three good measurements...
Old 10-30-2019, 09:04   #9 (permalink)
Member: 1939450
Thanks Meter: 158
No harm is made when you do make a jumper.
Just a suggestion.
Old 04-25-2021, 22:32   #10 (permalink)
James-R's Avatar
Member: 104911
Thanks Meter: 40
Did you solve this problem?
Old 05-04-2021, 22:40   #11 (permalink)
James-R's Avatar
Member: 104911
Thanks Meter: 40
? thanks....................
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.14559 seconds with 7 queries
