iphone 7 plus apple logo problem but the phone is work on itunes hy all I have a strange problem phone works on the program I tunes see you data but on the phone attached to the apple logo i flash full ios 11 but same :eek: how the phone is working but lcd apple logo |
Iphone 7/7+ needs home key connector to be properly connected for the phone to boot properly. Check for home key strip if disconnected. Or probably the strip might have been accidently cut off. Hipe that helps. |
this complaint have different solutions first you try to downgrade ios ,secondly refix sencor strip or check home button is ok,finally tryto reball or change audio ic |
I will do and give you results thanks |
check home buttom if its not connected phone can boot up only apple logo |
I I have the same trouble Did you get a solution? |
sam problem hereeeeeeeee |
Same problem here Envoyé de mon iPhone en utilisant Tapatalk |
These days many customers complaining same problem after they updated there devices to 11.1.x please use 3utools to downgrade your device to 11.0.3 |
restore it with beta soft. and original display |
problem fix for me i am change U10 in home bouton it work now :) |
please just 3utools and retain user data option tick and latest version flash 1000% Done. Me tested this solution and many devices done by this tools |
1 Attachment(s) Quote:
