01-24-2019, 12:52 | #4 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | just restore the phone in DFU mode, if not succeed and give you error, flash damaged use any tool to repair it like ( Naviplus Pro3000S or JC PRO1000S |
01-25-2019, 16:43 | #9 (permalink) |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | JC PRO1000S the best only problem expensive but you don't need any flash to remove all buy jig iphone5 to iPhone X also iPad , me just get it last week check ihereer : [url]https://www.jc******** Last edited by orx; 01-25-2019 at 17:02. |
01-25-2019, 17:01 | #10 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | Yes bro , too me use jc pro but it was just an ironic clarification on naviplus pro 3000s that actually supports only nand and not PCIE |
01-25-2019, 21:05 | #11 (permalink) |
No Life Poster Join Date: Mar 2007 Age: 39
Member: 475448 Status: Offline Thanks Meter: 60 | Update: i replaced battery, front flex, restored again, but sometimes not starting. Sometimes working everything fine. After restore, the Apple logo with status bar is freezing on 3/4. The reboot sometimes and Than working... I dont know, what is problem... Any experience for this failure? |
01-25-2019, 21:28 | #12 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | If restore goes well and yet the phone stuck on Apple logo or take's very long to boot. Then you can check the following. 1st check if the fingerprint strip is not cut while opening the phone. This happens alot. And if you try to boot the phone without home button it takes long time too boot. So that could be the reason. Second it can be faulty Audio IC which most probably it IS. And maybe some of the audio Ic pads could also be damaged on the board, which have to be repaired. Hope that helps. |
01-26-2019, 08:00 | #13 (permalink) |
Member: 475448 Status: Offline Thanks Meter: 60 | i tired without home flex, same result, after successfully restore the process bar is freezed, and rebooted the phone. i will try reball the audio codec, but if the phone booted fine, the speakers, mic's are okay... |
01-27-2019, 05:27 | #14 (permalink) | |
Member: 821646 Status: Offline Thanks Meter: 507 | Quote:
The speaker's and mic's are always ok. Its the Audio chip that causes the Audio functions to stop working. Faulty Audio IC will cause delayed boot or even if the phone boots the Audio functions will Fail. | |
01-27-2019, 07:49 | #15 (permalink) |
Member: 475448 Status: Offline Thanks Meter: 60 | You are right, i dont think audio ic failure, because when successfully boot, the audio codec working fine, and not long boot time. I reballed Nand, but some results. |
