12-04-2017, 12:32 | #1 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2781341 Status: Offline Thanks Meter: 18 | How To Fix No Service On iPhone 6? No service and search after a bump. no sending text, receiving phone calls, and making out phone calls. some websites consider it was a design defect of iphone 6's bonding pad. so it would be come out easily after a bump. Did you ever hear about this design defect? and any good solution? |
12-04-2017, 23:51 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | http://forum.gsmhosting.com/vbb/f631...rvice-2239656/ I made this solution. It works most of the time.. it happens because the frame bends and traces and solder joints break. But reballing baseband ic and jumper the 2 broken tracks is not always the solution. Could also be an other problem with an other ic. Like the network amplefier or rf pmic |
The Following User Says Thank You to HDccam For This Useful Post: |
12-06-2017, 10:16 | #3 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2762729 Status: Offline Thanks Meter: 32 | iPhone 6 No Service Hardware Fix Solution Go to Settings – General – About, if the IMEI code displays right, SIM card readable, and Modem Firmware functions normally, maybe the U1 Y1 pin of the baseband CPU is disconnected. |
12-13-2017, 04:58 | #4 (permalink) |
Crazy Poster Join Date: May 2017 Location: shenzhen
Member: 2713523 Status: Offline Thanks Meter: 15 | You can try these steps. 1. Check In With Your Carrier About Your Account 2. Update Your iPhone’s Software and Carrier Settings 3. Reset Network Settings 4. Check Cellular Settings On Your iPhone 5. Take Out Your SIM Card 6. Check For Water Damage 7. Back Up And Restore Your iPhone, But Read The Warning First! 8. Contact Your Carrier Or Repair Your iPhone Fast Repair Guide For Your iPhone 7 No Service |
The Following User Says Thank You to zhudy For This Useful Post: |
12-14-2017, 23:15 | #5 (permalink) | |
Major Poster Join Date: Dec 2007
Member: 657332 Status: Offline Thanks Meter: 16 | Quote:
very useful XD Sent from my iPhone using Tapatalk | |
The Following 2 Users Say Thank You to dvdbackuper For This Useful Post: |
04-24-2020, 07:43 | #7 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2797527 Status: Offline Thanks Meter: 4 | 1. Hard Restart 2. Check Carrier Service 3. Reset Network Settings 4. Reset All Settings 5. Check SIM Card 6. Check Cellular Data Settings 7. Update Software 8. Toggle Airplane Mode 9. iPhone System Restore 10. Check Water Damage |
